6port sleeve removal w/actuators?
ok it might not be claer from the title but is there any way that i can remove the 6 port sleves and keep my actuators? this way i can have the extra flow and have the low end that i want i had them wired on my old rex and that didn't work out to well the top end was better but the bottom end was sure no trader off! so any way please give me your opinions
tia
tia
Without the sleeves the actuators are useless. You could remove the sleeves and keep the ACV and air pump so your VDI would work still. Your question is kinda unclear. The model of your car would help alot also. Searching some of the older threads would probably answer your question in great detail. Try searching under the word "sleeves"
sorry it's an 87 w/o vdi. why wouldn't they work w/o the sleves would ther not be a seal for the back preasure to actuate? or would it not bolt up because they are bolted to the sleves? or how much low end do you lose with them just removed is it equivalent to wireing them open? sorry if it's unclear i thought i was being clear basicaly i want to remove my 6 port sleves and then reatatch the actuators so that they open properly so i can have a little extra flow when they do open
Nope - your sleeves **should** rotate in the intake port. I tore my engine down and noticed my 5/6 port sleeves were stuck closed. Could be what contributed to the apex seal breaking on the rear rotor - running too rich at high rpm --> excessive carbon buildup --> crack!!!
Steelwheelz
Sep 15, 2015 03:22 PM
