hard time to start
Old Mar 19, 2006 | 09:46 PM
cherdjc's Avatar
Question hard time to start
I recently fully upgraded my fd to a single gt35 turbo. It takes about 5 to ten minutes of off and on cranking before it starts slowly...then once its warmed, it starts easily. I have a 255 walbro fuel pump. 550 primaries and 850 secondaries.
sometimes i have to unflood the spark plugs.....
Does this have to do with compression? need help?
thanks
Old Mar 20, 2006 | 01:19 AM
signofinfinity's Avatar
Coyote
what engine management?
Old Mar 20, 2006 | 10:42 AM
crazyrx7's Avatar
Big Daddy!!!
Your only running 850's for your secondaries??? You must have ***** of steel!! Upgrade those secondaries ASAP!!! And ya what are you running for ecu. You might of fouled your plugs. Take them out and check them.
R.K.
Old Mar 21, 2006 | 01:25 AM
cherdjc's Avatar
i have aem ems...
Old Mar 21, 2006 | 07:49 AM
Coyote
check you initial pulse start fuel enrichment... it seems you are getting to much initial fuel add on.... i had a similar problem, starts and see a whif of black smoke
hot start is it alway ok? or is it a bitch to start?
george
Old Mar 23, 2006 | 08:07 AM
cherdjc's Avatar
yeah hot start is easy , if it sit for a while then it's a bitch ...
Old Mar 23, 2006 | 12:59 PM
Coyote
seems to me like a leaky injector....
have you got them serviced recently?
Old Mar 29, 2006 | 09:33 PM
myfc3s's Avatar
That's what she said...
What up LB brotha!!
thanks
If you need some help to fix that hick up, on the FD just holla!
Old Mar 30, 2006 | 11:40 AM
RenofHeavens's Avatar
Famous Phil's Cheesteaks
If it had low compression it would be a bitch to start when warm, so that is good :-D
Linky injector's are way more $ than an engine.
Old Apr 7, 2006 | 01:15 PM
YayeR's Avatar
yeah i've been having similar problems.. i'm on haltech ems. 720/1600s, the injectors are new i don't think they're leaking but i'm not positive how to check?
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
