Sponsored by: CARiD
media blasting
Old Mar 10, 2006 | 06:20 PM
Carzy Driver's Avatar
Law Breaker
media blasting
Is it ok to media blast the iron(s) surfaces with 80 grit glass bead? I can't get the coolant seal grooves cleaned out and this seems to be the best idea.
Old Mar 14, 2006 | 09:22 PM
tinvestor's Avatar
Dental tools and "super clean" by castrol lay iron flat and allow the super clean to soak in to the crap and use dental tools and old side seals to get it out. Is it rusty? If so use CLR and let that soak but bead blasting I think will have a profound affect on the sharpness of the water jacket grooves
Old Mar 15, 2006 | 12:14 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
crushed walnut shells for engine internals.
Old Mar 22, 2006 | 02:39 AM
Law Breaker
I used muratic acid and started a fire, it reacted with the red mechanic rag, smoked and then caught fire. Other than that, it worked fairly well, but there is still a many spots where the rusty krusty coolant seal crap is stuck. I've used dental picks and that did ok, but takes forever and a day. I do have a couple of a irons that have had the coolant groove break away that have served as porting practice, so I guess any media blasting will be preformed on them first, just to make sure. Thanks for the help.
Old Mar 22, 2006 | 07:25 AM
banzaitoyota's Avatar
What Subscription?
IF I were to media Blast. I would use a 80 Grit Glass Bead, I would also mask of the wear surfaces of the iron with a couple layers of heavy duty Duct Tape (or better yet: Resist Masking, used by signmakers)
