Different boost problem, help please!
Old Mar 3, 2006 | 02:24 PM
cloead's Avatar
sold--no longer in debt
Ok so I posted this in the third gen section and it wasn't getting attention so I figured I'd try my luck here.
So my car was tuned to 20psi, everything was great all day. Near the end of the day I notice my boost is trailing off towards redline. Before this it would hold a solid 20psi all the way to 7500rpms.
Now, no matter what the boost controller is set it, it will lose 3-5psi as I get to redline. I've tried a new boost controller, redoing all couplers, etc. I replaced a few vacuum caps, and when I was out testing it I blew one of them off. And even with it off I would make 15psi, and then it would still trail off towards redline.
Anyone have any clue what could be causing this? What happened today makes me think it isn't just a boost leak. Any help would be appreciated!
<!-- / message --><!-- sig -->
Old Mar 4, 2006 | 01:36 AM
cloead's Avatar
Swapped plugs tonight, got the same thing. So lost. Help please?
Old Mar 4, 2006 | 06:46 PM
Asleep's Avatar
7 Rx-7s since 1980
Do you have any logs of it maintaining 20psi up to 7K rpm? Who tuned it?
No boost leaks? Did you take all the couplers and pipes off and reconnect them all? Did you pressure test it? If you did, describe how you did it and how much PSI you were pumping in with what kind of compressor.
What turbo? Could be turbo is running out of "huff."
Old Mar 4, 2006 | 07:37 PM
cloead's Avatar
No logs, rx7store tuned it. No boost leaks anymore. I did a pressure test by capping the turbo and putting my compressor line on a fitting. Got about 10psi through it before it would blow the cap off the turbo. Did this with my 60 gal compressor. Turbo is from the gotham racing gr63 kit.
Old Mar 4, 2006 | 09:50 PM
Asleep's Avatar
7 Rx-7s since 1980
Are you sure it was hitting 20psi and holding it through to 7K rpm? I am sure Steve K. or someone will jump in and address my inuendo, but I am wondering if that turbo/engine can flow that much air up top. Since there are no compressor maps, and all I know is what I can read on a map and have seen with my own two eyes and that the turbo you have is non-BB and is supposed to make LESS power than the GT35r, is it running out of air?
Tony
Old Mar 4, 2006 | 10:12 PM
Jason's Avatar
The one
From what I remember from the Dyno logs it would hold 20 lbs until redline. The engine has a large port job on it.
Old Mar 4, 2006 | 10:58 PM
Asleep's Avatar
7 Rx-7s since 1980
Take it back and get the store's help in figuring it out.
Old Mar 5, 2006 | 12:22 AM
cloead's Avatar
I would but I'm broke.
Old Mar 6, 2006 | 07:27 PM
cloead's Avatar
So... anything?
Old Mar 6, 2006 | 07:42 PM
Jason's Avatar
The one
Does it hold boost at 16 lbs?
Jason
Old Mar 6, 2006 | 09:47 PM
cloead's Avatar
Doesn't hold boost at any psi. At 16psi it would drop to about 10-12. Here's a picture of the plugs I just pulled and replaced yesterday (if it matters/helps any).
edit: the plugs pictured arent b10egv's.. just letting everyone know so there isnt any confusion, im just running 9's all around.
Old Mar 6, 2006 | 10:26 PM
Jason's Avatar
The one
Only thing I can think of is maybe there is an issue with the boost controller. Just run boost from the wastegate and see what you get. It should at least hold boost pressure based on what lb wastegate spring you are running. Probably between 7-10lbs.
Jason
Old Mar 6, 2006 | 11:16 PM
KaoticFdR1's Avatar
Be a Hero...Punch a Koala
What boost controller are you using?
Old Mar 6, 2006 | 11:22 PM
cloead's Avatar
I've tried a few manual boost controllers all with the same results. Jason-- I'll try that tomarrow I guess.
I'm back to running a hallman boost controller right now.
Old Mar 7, 2006 | 07:42 PM
cloead's Avatar
So I tried running 15psi today without my hks twin-power.. and it did not fix the problem.
Old Mar 7, 2006 | 09:43 PM
Asleep's Avatar
7 Rx-7s since 1980
Do what Jason asked and stop trying random things.
1) remove boost controller and run WG off of manifold/post turbo reference only. For a Tial and most other WGs that would mean venting the TOP port, and use the side port right off the compressor housing.
2) whatever your spring pressure is, that is what you should see for boost. If 10, then you should be able to hold 10. If not, check for leaks or defective WG.
3) let the data/results drive what you try next. Random stuff like spark plugs or ignition control don't fit in yet.
Old Mar 7, 2006 | 11:54 PM
cloead's Avatar
Yeah, well people telling me to run with no vac source to the wastegate.. yeah that was a bad idea. Anyways after watching my boost gauge fly.. I think I've determined that I have a boost leak.
I used two boost gauges, my normal one on the UIM, and then one attached to my turbo.
As the boost dropped at the manifold, it held solid at the turbo. I had the controller set to about 16-17psi, and at redline, the gauge hooked up at the TURBO was still reading 17psi, and the gauge hooked up to the manifold read about 13-14psi. Am I wrong here?
Old Mar 8, 2006 | 07:26 PM
cloead's Avatar
Old Mar 8, 2006 | 09:24 PM
Asleep's Avatar
7 Rx-7s since 1980
Obviously you followed someone's advice to figure out that you have a boost leak. Or did you come up with that on your own?
About the method of testing your WG and it being a bad idea, did you follow directions or did you adlib and disconnect the wrong hose?
Old Mar 8, 2006 | 10:24 PM
cloead's Avatar
Is there a reason you have to be a complete *******? Sorry I guess, apparently I did something to **** you off. Just stop replying if it's bothering you that much.
Old Mar 11, 2006 | 09:40 AM
Asleep's Avatar
7 Rx-7s since 1980
Did I call you a name, silly boy?
You method for solving the problem was to throw random solutions at it...rather than letting the testing and the data drive the solution.
You have people giving you advice on the phone...and ignore and don't follow it right.
You have a shop owner giving you advice after the sale...and you ignore it or don't follow it right.
You have people who are trying to support you in the forum, and you waste their time by not listening.
The only good thing to come out of your problem is the knowledge that your buddy Coltboosting acutally may have some good problem solving skills and was able to impart some on you on the boost leak issue.
If I was going to start with name calling it would start with "dense."
You might need to expand your vocabulary a little bit and get some more descriptive words into your own lexicon.
Old Mar 11, 2006 | 03:04 PM
cloead's Avatar
Read the whole thread--and in the 3rd gen section, people were claiming that ignition could be the source, as well as exhaust backpressure.
I followed Jason's advice, he said my boost controller was broken, and then to take then to uninstall the boost controller.
And silly boy? Wow. I knew this forum had some ******** on it, but I think this is the first experience I've had with one. I hope you enjoy making fun of people on an online forum. Have a nice life.
Old Mar 11, 2006 | 08:35 PM
cloead's Avatar
And evidently it's not a boost leak problem after all. Did a pressure test up to 17 lbs, found one leak. Fixed it and went out for a drive. Still doing the same exact thing. In third gear it would go from 15psi at 4500rpms to about 11psi at redline. In fourth it wasn't as bad. 15psi at 4500rpms and maybe 13.5-14psi at redline.
Old Mar 11, 2006 | 10:32 PM
Asleep's Avatar
7 Rx-7s since 1980
Reread the advice. Get somebody else to read it with you and explain it. Try to remember the conversations and what people told you. Try following it. Stop acting like a child and a idiot.
Insert something profound as the last words...make it good...it's all yours, child.
Old Mar 12, 2006 | 04:34 AM
cloead's Avatar
How am I acting like "a child and an idiot?" Please, enlighten me. Why do you even bother to keep replying when you have nothing informational to ad? Get off your high-horse already god damn.
