How To's, what would you guys like to see??
Old Feb 5, 2002 | 01:26 AM
Agent_D's Avatar
rawr
ok, ive done my fair share of work on my 4 RX's that ive owned, anyone want any how to's for anything on the 2nd gen 86-88 n/a's?? just post it here, if ive done it, or know how to do it, i will post a how to on it.
Old Feb 5, 2002 | 01:30 AM
Scott 89t2's Avatar
SOLD THE RX-7!
how do I turbo an 88 N/A
(ducks and hides)
Old Feb 5, 2002 | 01:33 AM
Felix Wankel's Avatar
Super Newbie
(ducks and hides)
I got beat to it
Old Feb 5, 2002 | 01:34 AM
supergoat's Avatar
Eggs are like fowl cheese
How about a how-to on removing the intake manifold and the 5th/6th ports.
Old Feb 5, 2002 | 01:36 AM
Agent_D's Avatar
rawr
i was thinking the same thing Supergoat, that was the first thing i was gonna post, you read my mind,
hey scott, refer to your Avatar (runs and hides)
Old Feb 5, 2002 | 01:48 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I tried but I couldn't find anything on it
Old Feb 5, 2002 | 01:49 AM
Super Newbie
Your avatar didn't give me **** on the ATF treatment either....
Old Feb 5, 2002 | 01:57 AM
How about a wiring diagram to build your own homemade fuel computer... I know fc3s has one for turbo cars, with a built in FCD but is their one for N/A cars ?? that would be cool....
Old Feb 5, 2002 | 02:30 AM
Agent_D's Avatar
rawr
ill see if i can get to that later on fuzzi, im gonna be going to college for auto mechanics next semester and i will see if i can get a write up on that when i go.
hey scott, make a url reference link in your Avatar, make it go to the search window when you clikc on it then in your sig you can put, IF YOU NEED N/A TURBO SWAP INFO OR ATF TREATMENT INFO, CLICK ON MY AVATAR
(ducks to avoid flying vase)
Old Feb 5, 2002 | 02:49 AM
Super Newbie
You just gave me an idea
Old Feb 5, 2002 | 02:50 AM
Agent_D's Avatar
rawr
your avatar too felix
Old Feb 5, 2002 | 02:59 AM
Super Newbie
Ah, you can't make links in your avatar, but I messed with the sig a little...
Old Feb 5, 2002 | 03:04 AM
Agent_D's Avatar
rawr
AHAHAHAHAHAHAHAAH, nice felix, nice
Old Feb 5, 2002 | 03:16 AM
easy p-cheesy's Avatar
SPORKY
felix. you need one more.
wiring open your 5th and 6th ports!
Old Feb 5, 2002 | 03:21 AM
Super Newbie
Good call.
Old Feb 5, 2002 | 05:54 AM
how to's needed: polishing upper manifold, lower intake manifold gasket replacement, turbo removal / checking for play, acv / emmissions valve removal, vacuum line placements!, door handle change / fix, hmm what else do i need
Old Feb 5, 2002 | 07:05 AM
Roy James's Avatar
My cars louder than yours
On a serious note.... someone in here that has turboed an N/A should post a How-to with pics..... bc the search key can only give you so much....--ducks in case--
Old Feb 6, 2002 | 01:51 AM
if you need pics, your not ready!
well actually depends if your doin the whole engine / driveline swap or just the exhaust manifold / turbo/ lower & upper intake swap. And depends if your using original ecu or aftermarket. i think there is a writeup on it somewhere.. i know ive seen it..
Old Feb 6, 2002 | 02:50 AM
NevadaLoneWolf's Avatar
Needed.....AC removal....PS removal.....
Old Feb 6, 2002 | 02:53 AM
Agent_D's Avatar
rawr
ahh yes, ill do the a/c removal soon, and the p/s removal ill have to look up that one, none of my cars have had p/s except my auto but i didnt remove it myself
Old Feb 6, 2002 | 03:03 AM
Cool. Thanks a lot. Nice to have somone actually answer back to those requests w/o flaming....
Old Feb 6, 2002 | 05:49 AM
hIGGI's Avatar
I would like to see How-To for porting wastegate ;o)
Old Feb 6, 2002 | 07:06 AM
Josepi's Avatar
Despise Enmity
I'd like to see all these how-to's in one easy to remember location .
Old Feb 11, 2002 | 11:51 PM
can u please send me the link on the wiring diagram to the homemade fuel computer?? thanx i would appreciate it a lot
Old Feb 11, 2002 | 11:57 PM
Super Newbie
http://k2rd.freeservers.com/FC3S/MOD.../wastegate.htm
Its super simple. Take turbo off, take the wastegate cover off, and port like ****. Mines the size of a nickel with a bigger flapper thing welded in.
