NEED INPUT main bearing question
Old Feb 21, 2006 | 01:24 PM
ProjectD's Avatar
I'm on a Boat!
Is there too much were on this bearing to safely reuse it? [IMG][/IMG]
Old Feb 21, 2006 | 01:31 PM
13btnos's Avatar
Yes it is too much wear not worth using that without replacing the bearing. Bearing's are like $53 each. If that rear is that bad I would go ahead and replace all the other bearings also.
Old Feb 21, 2006 | 01:40 PM
diabolical1's Avatar
i'd change it.
Old Feb 21, 2006 | 01:49 PM
ProjectD's Avatar
I'm on a Boat!
Thanx for the input. I've changed the rotor bearings already. i wasn't sure if that would work or not. I quess it would be best to change both main bearings also? Even though one barely shows any copper?(not pictured). I called mazda and they said they are like $63 each. Can anyone tell me the different sizes? Mazda told me there were 10. I've got the measurment for the e-shaft journal just need the bearing sizes so i can get the right clearance.
Thanx again for the help guys!
Old Feb 21, 2006 | 10:55 PM
dude, call Mazdatrix. the stock main bearings are listed for about $53.
http://www.mazdatrix.com/getprice.as...m=10-E260-NF01
whinin
Mar 30, 2019 07:53 PM
troym55
23
May 25, 2016 12:42 PM
