Where to buy fuel rail kit..??
Old Feb 21, 2006 | 05:40 AM
Hi
I am about to put a HKS T51 kai kit on my FD, and i shall buy a fuel rail kit with 1600 ccm injectors. But where is it best to buy the fuel rail kit..???
I have seen this kit on Rorary exteme..:
http://www.rotaryextreme.com/fuelkit.jpg
And this is the kit from RX7 store..:
http://www.rx7store.net/product_p/extremefuel.htm
I want to here if anybody have good/bad things to say to each the kit...
Or if You have a third place to buy the kit I will be very interested...
Thanx
Old Feb 21, 2006 | 06:38 AM
rxrotary2_7's Avatar
http://kgparts.com/newfuel.htm
Old Feb 21, 2006 | 12:44 PM
XSTransAm's Avatar
Ee / Cpe
i got my kgparts rail setup from rx7store.
Old Feb 21, 2006 | 02:29 PM
DCrosby's Avatar
No it's not Turbo'd
Got mine with the turbo kit from a-spec, other than that both Jason @ Rx7store, and Chuck are quality guys,and carry quality parts.... I don't think you can go wrong.
The Only issue I had was with fitment on an aftermarket LIM, and the Rail I got from A-Spec... so maybe make sure everything will fit, or get a re-asurance from whomever you buy this from....
Old Feb 21, 2006 | 07:45 PM
mono4lamar's Avatar
In the burnout box...
kg parts... nuff said
Old Feb 22, 2006 | 08:33 AM
funklove's Avatar
In rotor we trust!
KG parts
Old Feb 22, 2006 | 08:51 AM
mpfcc's Avatar
NRX7HVN
Got mine from A-Spec...
Old Feb 22, 2006 | 09:09 PM
blackdemon04's Avatar
Looking at the pictures it seems like a-spec, rx-7 store and rotary extreme all sell the same kit. I've had the priviledge of putting a a-spec fuel kit on my buddy's fd
Old Feb 22, 2006 | 09:48 PM
Jason's Avatar
The one
The only reason the injectors would feel sloppy is if you werent using LIM spacers on the injectors. No Need to spend an extra $200 on the rx7.com kit.
Jason
Old Feb 23, 2006 | 09:18 PM
Poweraxel's Avatar
-------whoops accidently posted my response to the poster 2 posts (blackdemon04<SCRIPT type=text/javascript> vbmenu_register("postmenu_5336424", true); </SCRIPT> )above me, so his post might look wierd.. clicked EDIT instead of the REPLY button..sorry about that .. if you want please repost it, check your PM's-----
but anyway....
as Jason said, the spacers werent used. I personally know the fuel kit from a-spec comes with the aluminum spacers so maybe your friend dropped them or lost them before you did the install as they are quite small.
based on rx7.com pricing: http://www.rx7.com/store/rx7/fdfuel.html theyre kit is $995+$24 connectors = $1019 (rail/inj/pump/regulator) (+ another $20 for resistors, if needed)
astrum
24
Nov 15, 2017 08:44 AM
