Anyone Datalogging AFR and Injector Duty? I made a CFM calulator.
Old Feb 20, 2006 | 11:57 AM
pistonsuk's Avatar
Talking Anyone Datalogging AFR and Injector Duty? I made a CFM calulator.
Hey I made an engine airflow calculator that will tell the CFM (lbs/min) of your engine based on injector duties and AFR. This will be useful when selecting a new turbo.
More info here: https://www.rx7club.com/showthread.p...hlight=datalog
I am curious what our engines flow with different setups. So I am asking for some datalogs because I dont have access to my car right now.
This will work best if you datalog a long pull in 3rd or 4th from 2k-redline. (Of course on a closed course, or dyno
If you have a datalog with this displayed:
Injector Duty
AFR (or a voltage from a wb and the chart used to convert it)
RPM
Boost
Intake Air Temperature
email it to: rotor_rage@yahoo.com
You must also tell me what injector sizes you are running, where your staging bar is what pressure your injectors were flowrated at (probably ~43psi) and your static fuel pressure.
Please include a mods list: porting, exh, turbo size, turbine A/R etc...
I will post a link so it can be downloaded too.
Justin
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
