Local engine importer?
Old Feb 18, 2006 | 02:21 PM
The Spyder's Avatar
Never give up!
Any GOOD local Jspec engine importers?
Anyone have a good experiance with anyone?
Thanks.
Old Feb 18, 2006 | 04:51 PM
kettlman's Avatar
THE ONE. THE ONLY!
corksport has some in stock i believe.
Old Feb 20, 2006 | 09:27 PM
evileagle's Avatar
Reverse Cerberus
Like he said, I've got a couple S5s sitting in the warehouse right now.
Old Feb 20, 2006 | 10:30 PM
TooMuch4You's Avatar
how much do you guys charge and what is included on the motors?
Old Feb 21, 2006 | 02:56 AM
dr_strangelove5.com's Avatar
rx7 Bandit
That white FC in your signature pic has to be one of the sweetest that I've ever seen. I definitely drive an FC if it looked like that.
Old Feb 21, 2006 | 12:42 PM
evileagle's Avatar
Reverse Cerberus
CorkSport Type II body kit on that guy
S5 Jspecs are $1157, they come with whatever is stuck on them when they show up. Which 99.999% of the time is everything. I compression test them before we sell them so there won't be any surprises on the other end.
- Ryan @ CorkSport
Old Feb 21, 2006 | 06:39 PM
rx7 Bandit
- Ryan @ CorkSport
So does Corksport offer anything in the way of first gen body kits?
Old Feb 24, 2006 | 04:19 AM
Low-Key-Oly-fd's Avatar
i have a jdm long block, engine tranny ecu, no turbos. make offer and i have another complete R-1 front clip on the way,
Old Feb 24, 2006 | 12:20 PM
evileagle's Avatar
Reverse Cerberus
Nope
Old Feb 24, 2006 | 12:27 PM
jhammons01's Avatar
Carter 2.0
Hate to get everybody pissed off, but, you have a Junkyard motor in your cars engine bay. Just like any J-spec motor it just needs a rebuild. Not to mention the parts on it fit back in you car like the ones straight from the Factory...............
You can get all the seals needed for a rebuild for about $600 bux if you look in the 2nd gen Archives for a thread called 13b Rebuild kit by Karack.
If you have the ability to pull the motor out for a J-spec swap.......you definatly have the ability to rebuild it.
gtcd
30
Aug 19, 2015 02:44 AM
