2nd Gen noob questions prolly
Old Feb 14, 2006 | 08:50 PM
notveryhappyjack's Avatar
1 bar boost
I own a 1st gen and have been looking into buying a 2nd preferably turbo model, and have a couple questions
What would be considered good for compression numbers on a turbo engine?
What is the efini model? and what different about the engine compared to a TII engine?
Thanks -Aaron
Old Feb 14, 2006 | 08:52 PM
'87 turbo II's Avatar
Sleeper but still slow
efini is for third gens. the 2nd gen Infini is a Japan only model that weighed less and made more hp. you don't live in Japan so that doesn't concern you. as for compression, the FAQ sticky has the answer. Hope I helped.
Old Feb 14, 2006 | 09:09 PM
1 bar boost
the reason I was asking about the efini engine was because I'm looking into buying a FC with that engine in it.
If it is a Japan only engine it would not pass emmissions right here in the states?
I will check the search function I knew that was coming...haha
btw the numbers on the engine are 95 for both rotors I was just wanting to find out if those were good numbers or if the engine is needing a rebuild.
Old Feb 14, 2006 | 09:26 PM
MattB's Avatar
MattB
those numbers should be fine...
whinin
Mar 30, 2019 07:53 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
