Please help me identify the offset on these gram lights?
Old Feb 5, 2006 | 11:09 PM
FC3S Timmy's Avatar
ReTripleOG
Here is a list of all possible offsets
i think they look like 40 up front and 35 in the rear correct me if im wrong
Thanks
Old Feb 5, 2006 | 11:55 PM
maxcooper's Avatar
WWFSMD
If you have the wheels, take them off and measure. Measure from outer rim edge to outer rim egde (tricky to do with tire mounted, but you can figure it out). Then measure the backspacing (wheel pad surface to plane defined by outer rim edge on inner side of wheel). Then it is offset = backspacing - (width / 2).
-Max
Old Feb 6, 2006 | 11:01 AM
FC3S Timmy's Avatar
ReTripleOG
No i do not have those wheels i want mines to look similiar cause i like the offsets
Frox
Sep 8, 2015 08:36 AM
The1Sun
Sep 7, 2015 10:21 PM
