"Economical" Alternator Upgrade
Old Nov 6, 2003 | 09:01 PM
mar3's Avatar
Administrator
Exclamation "Economical" Alternator Upgrade
OK, here's the latest of what I have found after doing this conversion three times in various year's chassis. For those wanting to ditch the 50/55 amp alternator in your 1stgen, this is probably the cheapest way to kick up to an 80 amp alternator which should be plenty unless you've got a TON of stuff and you run it at max ALL the time...
First up, the universal wiring diagram reference...
For the TII alt plug, I've seen two different wire colors, but I think the yellow w/blue stripe and white w/green stripe combo may have been a conversion harness leftover itself. Underneath is a quicky reference to all the different color combos I've seen in the various chassis and the physical rlationship of the different plugs...early style on bottom. Just match your colors and you'll get it right. I need to state again that the 1979 part had already been converted to the later style charging system and the external regulator was eliminated. Since the car is gone, I really am not sure what is involved making the conversion, but these are how the wires in the engine bay harness attached to the TII alt when I replaced the old alternator originally installed by Rotary Performance.
Old Nov 6, 2003 | 09:02 PM
mar3's Avatar
Administrator
This is the actual install in the 1980 chassis...
Going from the top green arrow clockwise...
  • The '89/'91 TII plug itself which you must have gotten with the alternator to make this happen.
  • Tiny bit of the blue stripe on the yellow wire from the TII alt plug....the second TII alternator I got for the '83 had simply yellow and white wires with no stripes at all.
  • White wire w/black stripe...note that this particular wire's color scheme seems to be the same regardless of year...looking at the Haynes, you wouldn't think it so, but neither of the swapped alternators ever burned out.
  • 8 ga. wire going to the fusible link box on the strut tower of the '80...it never, ever gave me any problems with this routing, I might add.
Old Nov 6, 2003 | 09:03 PM
mar3's Avatar
Administrator
The actual shot of the fusible link attachment as physical proof I did it that way in the '80...
Old Nov 6, 2003 | 09:04 PM
mar3's Avatar
Administrator
This is the actual install into the 83 chassis...
For this install, I decided to completely take apart the plug of the TII alternator I picked up and run the '83 wires directly into the TII plug's metal spades...a lot of frustrating work because of the small size of everything, but the result is a completely factory look...the wire on the output pedestal this time goes directly to the battery, which is the method favored by Rotary Performance as evidenced in them doing just that to the long gone '79...
Old Nov 6, 2003 | 09:05 PM
mar3's Avatar
Administrator
Actually bolting in the '89/'91 TII alternator into the 1stgen chassis is the easiest part.
  • Just unbolt your old alternator and keep all the fasteners and related clips, if any...
  • Buy 5 or 6 standard size flat washers like you'll find at Home Depot that will just fit on the alternator bolt itself.
  • Use masking tape to hold that pack of washers together...trust me on this one...
  • Physically place the TII alternator into the mount, run the long bolt in and stuff your washer pack as shown in the diagram below and tighten.
Done...the pulley doesn't need to be changed and it will work with your old belt, too, although this would be a real good time to put on a new one, right?
Old Nov 6, 2003 | 09:13 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Thanks, nice work!
I'd cover up the + alt output wire's connectors since they're hot.
Old Nov 6, 2003 | 10:25 PM
hornbm's Avatar
FD > FB > FC
Damn you got mad drawing skills!
Old Nov 6, 2003 | 10:35 PM
85RX7GS's Avatar
Awesome Mario! I was just asked someone about the wiring diagram to do this swap and this looks very well done. Is the TII plug somewhat of an easy to find connector at, say, an autoparts store? Just wondering, 'cause I didn't get it with the 80-A alt. Thanks.
Old Nov 6, 2003 | 10:40 PM
hornbm's Avatar
FD > FB > FC
actually mine just broke, but I di find out that normal male/female couplers will go on perfectly!
Old Nov 7, 2003 | 04:32 AM
poweRX-7's Avatar
my tII alt dropped directly in, without any washers... i just had to keep the big spacer in there... and i didn't have to mess with the wiring
Old Nov 7, 2003 | 04:37 AM
frode's Avatar
what are you doing with the wiring for the original external regulator when you are using a alternator with a built-in regulator in a SA?
Old Nov 7, 2003 | 06:35 AM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
Your diagram reminds me of that book for type 1 Volkswagon that's called something like "Hows to keep your Volkswagon alive for the complete idiot" or something like that. Great work!
Old Nov 7, 2003 | 10:36 AM
mar3's Avatar
Administrator
Thanks, guys for the compliments on the sketches...all hand done for your viewing pleasure...I love stipple drawings...
The '79 that was converted was done by Rotary Performance of Garland, TX. I never looked to see what they did with the leftover wiring, but the regulator itself was gone. That particular car has since faded into the mists of history after taking down a utility pole late one rainy night on Cooper St....
Old Nov 10, 2003 | 01:24 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
i was in NOPI's main warehouse friday and saw that book on the wall in there show room..... they started out as a v.w. parts place now they mainly do rice converions
Old Nov 10, 2003 | 01:27 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
and i have a FEW friends that want to know how the hell you can jump or bypass the ext. reg. on rotary stuff...rx2,3 100 and repu... so if anybody knows PLEASE shead some light on this.
Old Nov 10, 2003 | 01:28 AM
Siraniko's Avatar
RX for fun
if you did the upgrade to a higher rating alternator, why do you still have the stock fusible links? Or am I missing something.
Old Nov 11, 2003 | 10:31 PM
jes's Avatar
jes
Rotorhead
Lightbulb Rx-7 Alternator Cross Reference and Swap Chart
Triggered by the ongoing thread about alternators on the 1st gen list, I put together this page using my collection of parts and Rx-7s as reference...
If you have any feedback, please let me know.
http://www.rx7.org/public/altxref.html
enjoy,
John
Old Nov 12, 2003 | 11:43 AM
fatboy7's Avatar
Got Boost?
I think I can.
You need some type of regulator. So first off, you need an FB alt, or something more exotic like Mario is showing here, the S5 style.
Then you have to make a decision, do you need the dummy light? If not then its really easy, if so, you need to get a choke & check relay from an FB.
If you eliminate the dummy light than all you need is a diode. if you keep the dummy light, then just wire in the choke and check relay's coil/diode in the orientation the diode would be, then wire in the NC (normally closed), NO (normally open) parts to the dummy light, and choke switch respectively.
Now for the good stuff:
1. Remove the alternator, and external regulator.
2. Install new alternator, using washers like shown by Mario above if necessary.
3. Grab the BLg (from key switch, ON and start) wire that went to the regulator and route it over to the alternator (or choke and check and add a wire from there to the alt).
4. Connect the BLg wire to both the anode of the diode(the side the arrow points away from, no white band on real diode) and to the BW wire coming from the ’83 alt (Y or WL if S5) .
5. Connect the Cathode of the diode (the side the arrow points to, the side with the white bar on a real diode) to the WB wire coming from the ’83 alt (W or WG if S5).
6. Start the car, and check the system voltage, to be sure the alternator is now working.
That’s it, your done… remove unnecessary wires and clean up.
Refer to Mario's wonderful drawing above, he did a good job, and it may be helpful for color comparison for different years.
Old Nov 12, 2003 | 12:07 PM
jes's Avatar
jes
Rotorhead
Exclamation Rx-4 & REPU alts...
Before anybody changes an alternator on an Rx-4 or REPU just because it has an external regulator...
A long time ago I "upgraded" the alternator on my Rx-4 to an alternator with an IC regualtor (came with the "low mileage" Jap. engine). Because of a reply I got about the alternator swap page, I happened to check the FSM on the Rx-4. It turns out that the Rx-4 had a 63A alternator. Guess changing the alternator may not have been an upgrade after all!
Old Nov 12, 2003 | 12:10 PM
fatboy7's Avatar
Got Boost?
enjoy,
John
Excellent reference... I have one thing to add.
namely, about he problem with Battery drain, and needing a relay. You don't need the C&C relay just a diode, wired in like I described above.
Without a diode, built into the C&C relay or by itself the field coil will remain slightly powered when you turn the car off. This will slowly drain down the battery. The voltage drop accross the diode is all it needs to almost completely turn the coil off.
The drain may continue, but at a lower rate (I'd guess around 3-4 weeks to drain). I personally perfer to just remove the battery from the circuit if I think I'm going to let it sit that long, but if it still bothers you add a resistor. Adding a small resistance (say 10-100 ohm, 1 Watt) inline with the diode will make it even less of a problem (a couple months min drain). Just make sure that the resistance isn't so high that the alternator won't turn on.
Old Nov 12, 2003 | 12:22 PM
frode's Avatar
Thanks fatboy, This is the information I wanted
Old Nov 15, 2003 | 01:25 PM
mar3's Avatar
Administrator
The point is that the fusible box will work fine with the bigger amp alternator and does not need to be "upgraded" if you don't want to mess with it.
Old Nov 15, 2003 | 01:46 PM
jes's Avatar
jes
Rotorhead
Question
I was looking at the '81 wiring and don't understand the source of the power drain some people are seeing. Both wires going to the alternator connector are switched... compared to the newer models that only seem switch the L terminal...
Old Nov 15, 2003 | 03:44 PM
82transam's Avatar
Never Follow
Yea I've had my 80 amp alt in there for over a year on stock fuseable links and it works fine.
Old Feb 10, 2004 | 10:54 PM
mar3's Avatar
Administrator
The wires are the same for an '84....here is an S5 80 amp alt into an '84 chassis I did this past weekend...this time, I chose to simply solder in the leads and shrink-wrap them since I'm selling red rex to a local buyer in May...
This first one is the pedestal clamp that makes in-car soldering a joy, seen holding the S5 plug and a bit of the '84s wire...
And then the completed install with a little rubber cap to make DriveFast7 a happy camper this time around...
One thing I should add....make sure you get a ring end that fits the S5 alternator's output pedestal before you start, so you'll have everything right there when you do the upgrade. The stock output wire from the chassis harness will have to be cut to length for the "new" alternator as it is way too long.
This alternator was off of eBay for $40.50 total, so this is the cheapest one I've done so far....and yes, I know, one day I'll clean the freakin' engine bay...
