Canadian Forum Canadian users, post event and club info here.
Any Pros at taking the dash out?
Old Jan 17, 2006 | 04:08 PM
Nismo Convert86's Avatar
400WHP or bust
Starting on the old car, and I don't have a clue as to how to get the dash out. I'm not sure what panels have to come out, and where the magical bolts are.
Old Jan 17, 2006 | 04:52 PM
Bass's Avatar
Grey-Bruce Rotorhead
Do A Search!!!
Lol
Old Jan 17, 2006 | 05:00 PM
400WHP or bust
Do you know how many threads of useless dribble from ReTed I would have to sift through if I went that route? He's the guy that still doesn't believe I dyno'd 240rwhp.
Old Jan 17, 2006 | 06:02 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
yeah, he can be kinda dumb sometimes!
I still haven't (totally) figured this one out myself yet.
there are 2 bolts on each end, the glovebox and etc all has to come out, the defroster vents at the top of the dash I think have to come out too.
I just poked at them with my finger until they broke, they're all pretty brittle.
it looks to be much easier with the windsheild out.
There is one bolt behind the idiot lights.
that's about all I know..
Old Jan 17, 2006 | 06:14 PM
RidicilousRx7's Avatar
1993 Mazda RX7 R1
i just finished and let me tell you...
NEVER AGAIN! but ya what terrh said seems to be right.
Old Jan 17, 2006 | 06:15 PM
400WHP or bust
Well thats kinda helped thanks. Any one expand on this?
Old Jan 17, 2006 | 08:13 PM
Feds's Avatar
More Mazdas than Sense
Feds has done it on 2 FB's, and is about to do it again, but for FC's Feds says "You're on your own"
Feds dynoed 250.
Old Jan 17, 2006 | 08:42 PM
400WHP or bust
Feds is full of **** lol.
Old Jan 17, 2006 | 09:35 PM
RXciting's Avatar
GrapefruitRacing?
Get a Haynes manual if you don't already have one or check the FSM.
there's 2 bolt in the center, 1 on each side, another 2 ( 4 ) at each end of the dash by the doors and if i remember correctly you have to unbolt the steering colum as well, but I believe i'm wrong on that last one.
It will also make it slightly easier if you remove the A-pillar pannels first. And if you have someone to help you yank it out, but you can do it by yourself as well.
Have fun
Old Jan 18, 2006 | 08:30 AM
Dom's Avatar
Dom
callin' tokyo
You may want to take a look at Manntis' site:
http://www.rotorhead.ca/topic.php?fl...=dashremoval_1
Old Jan 18, 2006 | 08:32 AM
Dom's Avatar
Dom
callin' tokyo
Uhm, looks as if the pictures are gone though,...
Old Jan 18, 2006 | 10:29 AM
ScrappyDoo's Avatar
Below is the summary I used aand found it to be comprehensive. Next time search you lazy bastard.
1. Remove seats.
2. Remove armrest/storage box, shift ****, shifter surround, and shift lever.
3. Remove ashtray/center AC vents/radio console/radio.
4. Remove steering wheel (one 21mm nuts holds it to the shaft). Remove instrument cluster surround and instrument cluster.
5. Remove plastic trim panels that are held on with one screw on either side of the center of the dash. Remove flat plastic panels on the ends of the dash that are normally hidden by the door when closed - those just pry off.
6. Remove 2 10mm bolts per side on the far ends of the dash. Pull the carpet flaps back at the center console and remove 2 12mm (they were 12mm on my wife's car - might be different in the earlier cars) bolts per side on the center console.
7. Pop off the center cap between the defrost vents. Remove the 8mm bolt there (not 1/4", this is METRIC ). Get a screwdriver and pop that whole defrost panel off. Wear gloves - it's sheet metal, and RAZOR sharp at the edge - I have SLICED my fingers open on it before.
8. With the top panel removed, there are 3 10mm bolts along the top of the dash to be removed that hold the dash on.
9. Drop the steering column - remove the crotch vent below the steering column, and remove the 2 12mm bolts that hold the column to the dash.
10. You should be able to start pulling the dash out. Pull it out a little ways, then unplug the harnesses. There are two big connectors on the driver's side, and one big one on the passenger side. There's also the connector from the logicon to the heater at the center near the windshield. There are also 2 flexy AC ducts to be disconnected.
Things I learned -
- You do NOT have to remove the logicon first. Leave it in the dash, and just unplug the heater connector once you start removing the dash.
- You do NOT have to remove the glove box - leave it be.
- It can help to unbolt the parking brake to give some more maneuvering room - 3 12mm bolts hold it in place.
- You will VERY likely break the center cap between the defrost vents when you pop it off. They're only a few bucks brand-new, though.
As far as the heater core is concerned, it's like 3 10mm fasteners and the two hoses in the engine bay, and it comes out. You do have to maneuver the outlet pipe on the passenger side to clear the AC evaporator, but it's not too bad.
The AC components were designed to be installed in this order - blower motor, evaporator, and heater core. You can easily remove the blower motor assembly with the evaporator in place, and reinstalling the heater core is MUCH easier if you unbolt the evaporator and pull it out a bit so you have some clearance to work with. You don't have to crack open the AC system or anything.
I do recommend when you're in there to remove the blower motor assembly and clean/reseal it. There are 3 8mm bolts/screws that hold the actual blower to the bottom - remove and drop it out. You'll probably find a forest of leaves inside . I also went to Pep Boys and bought some AC duct sealing foam - they're adhesive foam rubber strips. I resealed the blower motor to the fresh air duct, the heater core to the dash, etc. This makes a BIG difference - if you have any duct leaks under the dash, that will lower the airspeed of the air coming from the vents. The foam I got was with the weatherstripping, and I got two different sizes - one for the clamps that attach the duct from the heater to the evaporator and the clamp from the evaporator to the blower, and one for the heater core to dash and blower to fresh air.
It's really not that hard at ALL to pull the dash. And, yes, you DO have to pull the dash to remove the heater core. To remove the evaporator or blower motor, you just have to pull the glovebox and the panel under the glove box - both are easy to install with the dash in.
Old Jan 18, 2006 | 03:06 PM
400WHP or bust
Ahhhh shucks Charn, you sure are swell, actually I was hoping you would post because I know you did this last summer.
Thanks.
Old Jan 18, 2006 | 04:16 PM
400WHP or bust
Well thanks Charn, got it out, now to wait for warmer weather so I can start to paint the interior and fill the factory holes in the Purple car, then I need to get the carpet out of the Silver one, put it in the Purple one, Just as I get to the peddious part the weather gets shitty..... Such is my luck I spose. Pics are in my other thread.
Old Jan 28, 2006 | 05:42 PM
Feds's Avatar
I pulled the dash out of the S4 today. Actually easier than out of the 1st gen.
Plus, I dynoed 275. At the wheels
Old Jan 28, 2006 | 05:46 PM
400WHP or bust
275 hamster power?
Yeah it wasn't that bad, but you had this thread to look at.
Old Jan 29, 2006 | 11:19 AM
Feds's Avatar
Nah, I just had a bigger hammer, and wasn't too interested in putting it back in.
Old Jan 29, 2006 | 05:54 PM
400WHP or bust
That dosen't sound like something an engineer would say.... there something your not telling us?
Old Jan 29, 2006 | 06:59 PM
Ruskin's Avatar
Registered Loser
i followed this one when taking my dash out. it really wasnt as bad as everyone says.
https://www.rx7club.com/showthread.p...t=dash+removal
Old Jan 31, 2006 | 11:30 AM
Manntis's Avatar
add to cart
rotorhead.ca pix fixed
Old Jan 31, 2006 | 02:21 PM
400WHP or bust
Meh.
Old Jan 31, 2006 | 03:21 PM
The Wankler's Avatar
FKITALL
Word.......
dludden
Sep 13, 2015 10:28 AM
dludden
Aug 26, 2015 11:25 AM
cam_7779
Aug 18, 2015 07:48 AM
