Mountain RX-7 Forum Serving Montana, Wyoming, Utah, Colorado, and New Mexico
Yet another Non-Seq Question
Old Dec 27, 2005 | 04:05 PM
1.3V8KILLER's Avatar
Hey there, all of you that have done the non-seq conversion. What kind of programing should i run on my pfc? I was trying to figure out if i should keep with my settings now or if i should find a map that was set up for a small single and use it.
P.S. Is there any one in town that is good enough to do a good custom tune on the pfc?
Old Dec 27, 2005 | 08:43 PM
boostin13b's Avatar
You should be ok to run on the Map you have for the time being. The load ranges won't be changing at all, so the map shouldnt' need any changing really. Your just not going to be using the higher boost at lower RPM's portion of the Map. All the top end stuff should remain the same as stock.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
