S5 question
Old Dec 26, 2005 | 10:22 PM
eddierotary's Avatar
back with rotaries
S5 question
im gonna fix the FI on my S5 GTU and i wanna know if anything will cause to go on limp mode? like if you remove the emission stuff will cause it? thanks
Old Dec 26, 2005 | 10:28 PM
sar's Avatar
sar
Doin a rebuild.
The OMP failing will send it into limp mode. Other than that stuff will just mess up your mixture like your tps/thermosensor/tempsensor/afm being bad/off. If you remove the air pump/acv the 5th/6th ports and VDI will not function and you'll lose out on what most people consider 25hp. I believe thats about all you remove that affects power negatively.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
