Haltech Haltech E6K Question
Old Dec 23, 2005 | 06:39 PM
ilostmypants's Avatar
Timmaahh
I'm just having trouble finding a map for my car. I've been using a base map for the last few months (n/a) and now it's turbo and I need a map for it. Can anyone point me in the right direction? It's an 89 (s5) 550cc primaries 1000cc secondaries. FD stock fuel pump. Want to be running about 10 psi. T04B (I believe) .60 Cold side 1.32 Hot side. Lemme know if there is any other info to determine what map I will need.
thanks
Old Dec 23, 2005 | 07:48 PM
Turblown's Avatar
Turn up the boost
Try the EMS section on nopistons.com
Old Dec 24, 2005 | 07:16 AM
Timmaahh
1.13 hot side sorry
Old Dec 25, 2005 | 07:46 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Originally Posted by ilostmypants
....running about 10 psi. T04B (I believe) .60 Cold side 1.32 Hot side....
That turbine/compressor combination doesnt sound to me like it will be efficient at all, too big an exhaust A/R and too small a compressor. That is a turbo for a V8 big block. I always recommend turbine from .70 to .84, at the most, in T4 format, and a TO4E compressor is way better than a TO4B, I had a TO4E .70 A/R compressor paird with a T4 A/R 1.00 O trim turbine, that didnt spool very well and backed off from 16psi to like 13... didnt hold boost, sucked big time.
