What are these parts worth
Old Jan 28, 2002 | 04:51 PM
IAN's Avatar
IAN
Rotary Reborn!
I have a chance to buy these parts. 3 months old
HKS wastegate and Manifold
PFC F-CON
Turbo 60-1 to4 garret.
Any comments
Ian Skacel
88 10th AE
Old Jan 28, 2002 | 04:57 PM
Scott 89t2's Avatar
SOLD THE RX-7!
manifold and wastegate probably $1000us new, turbo around $750-$1000, and f-cons run around $400us used.
I wouldn't run the f-con with a full t04 though. I'd go standalone, haltech.
Old Jan 28, 2002 | 05:04 PM
IAN's Avatar
IAN
Rotary Reborn!
Haltech is expense. I thought that it would be fine to us the fcon. Thanks for the input.
Ian Skacel
88 10th AE
Old Jan 28, 2002 | 05:08 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well the f-con is ment for stock injectors which will max out around 250hp. and the 60-1 to4 is good for around 400hp so.... you need bigger injectors all around as well as a way to tune them in. which makes the f-con kinda useless. you can use the s-afc with the f-con, but in that case the f-con probably isn't helping much if any.
you'll also need another couple hundred for custom oil and water lines ontop of that price you buy the turbo for.
Old Jan 28, 2002 | 06:35 PM
IAN's Avatar
IAN
Rotary Reborn!
Thanks scott.
I guess it would be better to buy the wolf 3d.
The HKS manifold was $700, Turbo $1200, F-Con $1200, Wastegate $700.
This is in Canadian funds.
Just trying to save money
Coudn't you just replace the stock injectors for bigger ones and control them with the fcon?
Ian Skacel
88 10th AE
streetlegal?
Mar 17, 2022 02:46 PM
Im faster
Aug 19, 2015 02:57 PM
cam_7779
Aug 18, 2015 07:48 AM
