Haltech Emulator
Old Dec 9, 2005 | 06:11 PM
lovintha7's Avatar
Suicidal Death Missile
Emulator
I read this somewhere but I can't find it.
I just bought a new laptop to have, and I need DOS to run the E6K (Don't have yet, but am going to get) software. It's got XP on it, so there really isn't a DOS. What are you guys running software-wise on new computers to get the DOS stuff to run?
Also, I've got no serial port, only 3 USB ports, is there an adapter made?
Old Dec 9, 2005 | 07:22 PM
J-Rat's Avatar
Alcohol Fueled!
I have a dos boot disk that I use when running the E6K software.
Old Dec 9, 2005 | 09:57 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Does that actually work with the USB to Serial adapter?
I use Virtual PC with all DOS software installed on an XP Pro machine. But i do have a serial port.
Old Dec 9, 2005 | 10:28 PM
rmriggin's Avatar
no clever remarks...
http://dosbox.sourceforge.net/news.php?show_news=1
DOSBOX is a DOS emulator built to be run in XP. This should be the answer for running Haltek's DOS based software without needing to "boot" into DOS.
Old Dec 10, 2005 | 06:20 PM
lovintha7's Avatar
DosBox Install
Installed DOSBOX and mounted the c drive. All I need to do now is get a serial adapter.
Old Dec 10, 2005 | 09:34 PM
J-Rat's Avatar
Alcohol Fueled!
Muchas gracias!
Old Dec 10, 2005 | 09:42 PM
Rex4Life's Avatar
RX-7 Alumni
Did you try this?
At start menu, select run. Then type in cmd.exe and hit OK.
Not sure if this is a "full" dos, but it does give you the prompt.
Old Dec 10, 2005 | 11:43 PM
lovintha7's Avatar
Yea, I tried the command line in XP. The haltech software isn't too fond of it. You get the COMM 1 error, typical for 32 bit XP. The only problem I have with the DOSBox is that you have to mount the hard drive every time you run it. I'm not sure if there's a save feature or not. Granted it's a 1-line command (mount c c:\dosprog) after you create the dosprog folder in your C:\ drive.
I think this emulator is the ticket to run the DOS Haltech software though. I've played with it, and loaded some maps into the software, and it works like a charm. Just don't try to connect to the Haltech without it connected, it hangs.
rex7tuner
Rtek Forum
Aug 22, 2017 11:38 PM
freq
Rtek Forum
Jun 18, 2011 07:29 PM
1SWEET7
Rtek Forum
Feb 5, 2010 10:42 AM
BDC
Rtek Forum
Oct 10, 2008 09:38 PM
