info about A単EXi AX75F82 turbo kit...anybody?
Old Nov 24, 2005 | 08:54 PM
13bmaniac's Avatar
hello im looking info on this kit i already onw a t78 kit but have a frriend that want to buy one and is looking for info on this kit..
i saw on the apex web site that this turbo can support 600hp but im lookin for somebody who has install one on a FD.
thanks
Old Nov 25, 2005 | 02:14 PM
j9fd3s's Avatar
Community Builder
i know 2 people with the turbo kit. its made to order (took 18months!), and it wasnt cheap either. its a t3 sized exhaust housing. so i'm not sure about the 600hp number, they made just under 400rwhp at around 15psi, i think.
Old Nov 26, 2005 | 08:05 PM
superk's Avatar
I have the apexi ax75f92 and it is a t4. Jason from RX7Store.net got my kit in 1 week after ordering. It spools fast and does not fall off up top. Keeps pulling till redline. Has a 50mm water cooled waste gate. It is a really nice quality kit. You should call Jason and ask him for more info 614 771 8966. There is a picture of the turbo installed on his home page bottom left pic that says rotary engines on it. Hope this helps.
Old Nov 27, 2005 | 12:45 AM
elmfd3s's Avatar
Superk, what type of rwhp are you seeing with this kit, and at what boost?
Old Nov 28, 2005 | 12:27 PM
13bmaniac's Avatar
nice question what numers are you seen at 15 psi?
what engine?
at how may psi yo see full boost lets say 15 16 psi?
Old Nov 29, 2005 | 09:18 AM
RX794's Avatar
NYC's Loudest FD
I copied and pasted this from APEXi's website for you:
AX75F82 Middle Single Turbine
The AX75F82 high power turbo is designed for single turbo applications requiring excellent response with high horsepower output. Horsepower range per individual turbine is from 550-650HP. The AIRICK assisted ball bearing shaft produces nearly identical response characteristics as the AX53 series with a far more potent HP output. Skyline GTR RB26DETT motors have produced 550-640HP while rotary engines produce 400-500HP. The AX75 turbo assembly can also be purchased separately for custom applications and can also be mated to various Setup Kits for individual engine applications.
AX75F92 Turbine
To better suit the needs of our customers, many of the A単EX turbos are available in different compressor and turbine size combinations. The AX75F92 features the same size compressor wheel and compressor housing as the AX75F82, as well as the same quick spooling ball bearing center cartridge. However, designed for maximum power extraction of a single turbo application, the AX75F92 features a larger exhaust turbine and turbine housing. The result of the larger turbine is a dramatic increase in exhaust flow and turbo efficiency. This combination has proven itself to produce maximum power in the range of 500-550HP on rotary engines and 700-750HP on single turbo RB26 applications.
CONCEPT:
High power, high responce turbo designed for single turbo applications.
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
