clutch again
Old Jan 25, 2002 | 10:35 PM
zigger1's Avatar
clutch again
Hey, I filled up my clutch resevoir on my 87' and the clutch feels better but it still will sometimes get stuck on teh floor. I am sitting at a red light with it mashed in and when I go to put it in first my gears grind. I have to stick my foot under it and pop it back up. It will sring right back and work fine. Could it be a linkage prob or what? My next question is what sort of exhasut sounds good on rx-7s I do not want a whole system just two mufflers?
Old Jan 25, 2002 | 11:22 PM
Roy James's Avatar
My cars louder than yours
Check your Master and Slave clutch cyl for fluid, check your linkages in the back and such, get a Haynes manual (or, if you are cheap like me, go to the auto store and sit there and read it.. ) my clutch is funny, but not like that, when i bled my system, it was kinda funny like that, yeah, bleed your Slave cyl and see if that helps, im not the best with clutches, i just know how agrivating that **** can be, hope this helps some man, later.
Old Jan 26, 2002 | 07:08 AM
zigger1's Avatar
You ain't kinding man. How can you race red light ot red light with someone if you can't get into first (hehe)!!!
Old Jan 26, 2002 | 07:16 AM
Shamrock1054's Avatar
Hey Zigger,
I struggled with my clutch for months. Then I just said **** it! New master and slave, and a stainless line from RP. Solved all the problems and the clutch has never worked better.
Gregg
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
