Hydraulic Clutch Problems
Old Nov 17, 2005 | 06:52 PM
JerseyFc's Avatar
Hey I have a 1988 rx7 non turbo. It has stage 2 centerforce clutch that is pretty new. Today when I was driving something weird happened. When I hit the gas it doesnt seem like the clutch is engaged right or anything, I hit the gas and I barely move it just revs, but it still moves enuff to get around. If anyone has any clue what is wrong with my clutch system please help me out. If you want more information about the problem let me know.
Old Nov 17, 2005 | 06:55 PM
jono20's Avatar
hows the pedal feeling? how much clutch fluid left in the resevoir?
Old Nov 24, 2011 | 01:28 AM
FBOB's Avatar
FBob
bleed your system is all i would say. make sure you got everything connected. ran into bubbles in my system on my 626 project.
Old Nov 25, 2011 | 05:55 PM
mukurosfc3s's Avatar
are you sure its new?? did the rpm jump but no gain in speed?? if rpm jumps mostly a worned clutch disk..
Old Nov 25, 2011 | 06:48 PM
Phoenix Jones's Avatar
This first.
Old Dec 8, 2011 | 03:50 PM
gearheadls1's Avatar
Newbie
Ran into a pressure plate that was machined wrong once and wouldnt release properly
Old Dec 12, 2011 | 09:45 AM
rtrypwr98's Avatar
Internal problem. If it's not disengaging it's in the hydraulics....if it slips look inward. The clutch springs will keep it engaged if the fluid, master, slave have an issue.
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
