Sponsored by: CARiD
12aturbo disaster
Old Nov 8, 2005 | 06:49 PM
CELOS23's Avatar
Newbie
12aturbo disaster
hi um new to this i had a 12at engine re buit its extend port had new bearings gaskets and seals and rotors its running a big turbo computer and waste gate 4 x injectors 3inch exhaust ive done 4000kms running 12psi its mking 370hp at the fly wheel it has since dropped a rear stationary gear when we pulled it down noticed the center plate is ground out by both rotors any suggestions as to what would cause this and the stationary gear thanks marcel
Old Nov 8, 2005 | 06:54 PM
web777's Avatar
Might be oil starvation. Are you using a FD oil regulator?
Old Nov 8, 2005 | 07:29 PM
CELOS23's Avatar
Newbie
yes has oil pressure regulator that works worried about the center plate markings can this engine handle this power maybe needs dowelled ?thanks for your help
Old Nov 8, 2005 | 08:32 PM
trochoid's Avatar
Old Fart Young at Heart
Were the stationary gears pinned? Sounds like maybe they went walkabout. Post your question in the Rotory Performance section, or the Engine Building section on Nopistons.com, you will probably get a better answer there.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
