Need Help in GA
Old Nov 7, 2005 | 09:04 PM
Compilez's Avatar
OooooohWeeeee
Need Help in GA
I need help getting my engine started for first time. I have everything hooked up right that I know of and When I'm trying to start it, it just keeps turning but won't turn over. Hoping someone is willing to set a day up and come over and help me get my car running. Any takers? I'm in the Marietta/Kennesaw area.
Old Nov 7, 2005 | 09:15 PM
Tim Benton's Avatar
FD title holder since 94
stock setup or aftermarket ecu? Any error codes/check engine blinking?
Tim
Old Nov 7, 2005 | 09:30 PM
Compilez's Avatar
OooooohWeeeee
Small bridge port, 3mm seals. Stock ECU for break in then I have a Power FC waiting to be installed. Downpipe... As for the codes.. It's one long blink, then a short fast one after it, so is that #11?
Old Nov 8, 2005 | 12:59 PM
Crit's Avatar
No distributor? No thanks
I'm in Smyrna and rebuilding my RX-2. I'll put a little good karma out there, since I'll need to put my motor back in the car in a month or so. 678.779.4981. Give me a call.
Old Nov 10, 2005 | 10:29 AM
AYU's Avatar
AYU
bush meat
i think that's your air intake temp sensor for that code
Old Nov 10, 2005 | 11:12 PM
Compilez's Avatar
OooooohWeeeee
Ok, Crit just left here and we have figured out that we have no spark coming from the coil pack wire.
Old Nov 10, 2005 | 11:45 PM
Compilez's Avatar
OooooohWeeeee
I believe I know why I was getting that one... I left the sensor unplugged under the UIM. But that wouldn't stop the car from sparking would it?
Old Nov 12, 2005 | 03:39 AM
spyder_doo's Avatar
Since your in marietta just call up the guys at mazcare and see if they can help.
Old Nov 12, 2005 | 09:32 AM
hondaslaya's Avatar
SA hole
hey im in marietta and im off tomorrow if you want some help and are free give me a call (770)926-8912 ask for jeremy
