stock turbo 2
Old Oct 30, 2005 | 05:08 PM
Rotarywall's Avatar
Plan Golf
stock turbo 2
Hey guys I have a completely stock 89 turbo I am adding the racing beat complete exhaust system I know you need the fuel cut controller and also a new fuel pump but what else does anyone recommend when i add that im a little worried about running to lean or rich on my air fuel mixture. I would like to add everything at once so i run the least risk of hurting my car.
Old Oct 30, 2005 | 05:15 PM
McWheels's Avatar
Living, Breathing Nopiman
an Air-Fuel ratio gauge.
Old Oct 30, 2005 | 05:38 PM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
i wouldnt recommend a cheap air fuel meter to anyone...however if all you are trying to figure out is.. "ooh poop im too lean" that should serve to be some warning but with fuel pump and fcd you should be fine. that meter will most always say you are rich with a rotary.
Old Oct 30, 2005 | 06:30 PM
turbine's Avatar
a piggyback fuel controler wouldnt be a bad idea. also a rising rate FPR would work well
Old Oct 30, 2005 | 07:04 PM
88t2romad's Avatar
(_8(|)
port the wastegate
get a good aftermerket boost gauge
cristoDathird
28
May 30, 2019 08:47 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
