West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
East bay Nor Cal Cherry picker needed
Old Oct 28, 2005 | 09:48 AM
BASTARD's Avatar
So I popped my motor Monday morning on my way to work, hit the rev limiter for a sec and then the motor sounded like a sheep….Baaaaaaaaaaaaaaaaa definitely running on one rotor and wouldn’t rev . I got it home, pulled the plugs… cranked it over; didn’t even need to check compression, I could hear that there was no compression from the rear rotor. It was a stock Mazda reman S4 TII with a To4e and a E6X @ 10psi. This is the second Mazda reman that blew, the first one blew up after 1500 miles cruising on the freeway under vacuum(that motor and set up was all stock). So I am done with the Mazda remans, I will be building the next motor myself. At least this time the motor lasted 6k miles and I got to drive in the SS8 caravan. It will be a huge street port, balanced and I may even go with 3mm OEM seals. Anyhow I am most likely going to need a rotor housing and maybe a rotor so anybody have these parts let me know, but the reason I am posting is I will be needing a cherry picker. If anyone has one they would be willing to let me use I would be most grateful. I would be able to pick it up and return it on the same day. In return I would be willing to help with any RX work on your car. I would like to get the motor out next weekend.
Old Oct 28, 2005 | 05:36 PM
The Wankler's Avatar
FKITALL
I have one in Dublin!
email me. ckrall3@comcast.net
Old Oct 28, 2005 | 06:37 PM
I just bought one on craigslist with an engine stand for $100.
Why not get one there, use it, then flip it. . Arent you going to need it to put the motor back in?
Old Oct 28, 2005 | 09:49 PM
FKITALL
Yeah, I have and extra one. That would be the one I would lend ya. But, if you wana buy one, here it is!
Old Oct 31, 2005 | 09:31 AM
BASTARD's Avatar
Thanks Wankler, I emailed you
-g
Old Nov 6, 2005 | 12:53 PM
BASTARD's Avatar
Thanks to Wankler and his cherry picker i got my engine out, here is a picture of the damage so far.
Old Nov 7, 2005 | 12:25 PM
FKITALL
Hey, you are welcome BASTARD! Pic is broken.......................
Old Nov 7, 2005 | 03:59 PM
BASTARD's Avatar
damn picture... one more try
Machupicchu
Aug 17, 2015 08:27 PM
