Will this hurt anything?
Old Oct 27, 2005 | 12:24 AM
Green_Streak's Avatar
slower than granny
i just threw my Racing Beat downpipe/presilencer combo on and didn't get a chance to remove the air pimp or ACV. is it going to hurt anything? if so what/how/why? i'm planning on removing that **** this weekend but am wondering if i ought to pull the belt to the air pump now
Old Oct 27, 2005 | 12:53 AM
Makenzie71's Avatar
...94% correct.
what year car?
Old Oct 27, 2005 | 01:26 AM
slower than granny
it's an 88 FC3C
Old Oct 27, 2005 | 01:29 AM
Makenzie71's Avatar
...94% correct.
what the hell's an FC3C?
If it's an N/A then yeah, you'll have problems...your pot actuators won't work propperly. If it's a turbo then don't worry about it.
Old Oct 27, 2005 | 01:30 AM
jono20's Avatar
its should be fine to leave until you can remove it... though...
being an s4, your auxilary intake ports (6pi system) are activated by backpressure via the ACV tube that is connected to the cat. with this line disconnected you have a few choices:
-leave the 6pi and VDI system as is and suffer the top end power loss (please dont do this...)
-remove the 6pi sleeves (will offer some top end improvement, but is still not reccomended.
-activated the 6pi and VDI system via the stock air pump or aftermarket electric pump (reccomended!!)
-run a vacuum tube to the cockpit and blow in it everytime you are running over 3800RPM (good luck...)
Old Oct 27, 2005 | 01:34 AM
Tessai's Avatar
What will I drive next?
@Mak: FC3C = vert
s4's don't have VDI.
You should have gotten this type of presilencer:
http://www.racingbeat.com/resultset....rtNumber=16206
It's got a little hose for you to keep your working 6ports.
Old Oct 27, 2005 | 01:42 AM
Makenzie71's Avatar
...94% correct.
Originally Posted by Tessai
@Mak: FC3C = vert
learn something new every day.
Old Oct 27, 2005 | 01:51 AM
nexpo8's Avatar
Rotor7ven
ok so that lil hole thats in the presilencer is wat makes the 6ports working? cuz i took of my stock presilencer and replaced it with a bonez replacement pipe, there was a long *** skinny metal tube runnin to it and to the back of the engine. do i have to have that on??? is that y my 5th and 6ths ports are acting up???
Old Oct 27, 2005 | 01:55 AM
Makenzie71's Avatar
...94% correct.
If you drive an S4, then yes.
(can't remember if the S5's have the backpressure tube)
Old Oct 27, 2005 | 02:20 AM
slower than granny
that's racing beat right? (i thought i said i got the stuff from racing beat) but actually that's not the right one(you'll notice that it directs you to a different part number for my car) http://www.racingbeat.com/resultset....rtNumber=16209 that's the link to the stuff i got.
also jono, i know on the S5's the ACV controls the 5th/6th ports, but on S4's could i'm scratching my head as to what the ACV has to do with opening the ports. i was under the impression the whole reason to get the racing beat piece was for that pressure pickup. and if the ACV is necessary on S4's why is racing beat saying it needs to be removed(don't point out that they say the same on S5's cause i already know)
Old Oct 27, 2005 | 02:22 AM
KompressorLOgic's Avatar
I
yes having that much of a free flow exhaust and that tube not hooked up will cause them not to function, a lack of power above 5000 rpm would be a symptom.
there are several routes you can use to make them work again, the easyest is just to remove the pots, and zip tie the ports in the open position ans you will keep your high end power, however you will loose some low end torque. some other ways are discussed in the FAQ section and archives
yes the s5 does have that tube, as the tube is still used for the air pump to supply air to the cat to keep it happy
Old Oct 27, 2005 | 02:36 AM
slower than granny
kompressor, are you talking to me or nexpo?
