FI Conversion question...
Old Oct 26, 2005 | 01:24 PM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
I found a full set of FD intake manifold, throttle body, and injectors on ebay for fairly cheap.
Can I run it n/a? I absolutely LOVE the look of the FD upper intake manifold, and even though I'll be running n/a for now, it would seem like the only other mods would be to add a turbo and intercooler (and associated stuff).
I dunno... is it worth the trouble? Is it something I should bid on?
BTW, motor is a bridgeported 13B (built by MAZSPORT), with GSL-SE rotors, 3mm seals, and fairly new housings.
Lemme know.
Old Oct 26, 2005 | 02:00 PM
Turbo II-FB's Avatar
you souldnt be adding it for the "looks" thats stupid.. But I'm not sure b/c with t2 LIM can bolt to the FD'sd ,bu they need to be port matched or you haev to buy a 300 dollar adapter kit. I havent seen some one do that on a NA 13 nor do I think it possible with out a bit of fab
Old Oct 26, 2005 | 09:54 PM
Lee Lyons's Avatar
FI's a bitch...so have fun...lol
Old Oct 26, 2005 | 10:25 PM
steve84GS TII's Avatar
FB+FC=F-ME
The FD injectors,especially the secondaries,would be too big for an N/A engine.
Theres no reason you couldnt run it N/A provided you install and tune a Haltech or some other standalone ECU.Youll have to install a few other sensors on the engine,but it should work fine.
Although its not needed so much on a turbo engine,the FD and TII intake manifolds do have a little bit of dynamic tuning to the runners,which will help boost torque on an N/A engine.The non turbo 2nd gens went much furthur with this technology, with their aux. ports,longer intake runners and VDI valves(all rotary equivalents to VTEC)
Coochas
44
Nov 5, 2019 11:08 PM
