Question about full boost at partial throttle at lower rpm
I recently got an 88 TII (RTEK 1.7, 720 cc secondaries, SAFC II, S5 Turbo, at <10 psi, ported wastegate). The previous owner had the boost set at 12 psi w/stock intercooler (ive read this is bad), so i downtuned it to about 8-10 psi (autometer boost gauge) by adjusting the manual boost valve and was test driving it today.
Im new to turbo's, and I noticed that I can get full boost (~9 psi) when accelerating with partial throttle as low as 3500 rpm. Is this bad for the engine? The ecu isnt in full throttle mode, so is it going to lean out? Or does the ecu use the airflow sensor and automatically compensate?
This is why you downshift.
Welcome to the world of "turbo lag".
Turbo boost is not instantaneous - it needs to "spool" up before it makes max boost.
[QUOTE]The ecu isnt in full throttle mode, so is it going to lean out?[?QUOTE]
No.
Yes, the (stock) ECU adds fuel the more the airflow meter opens up.
-Ted
so what is the difference between getting full boost at partial throttle and full throttle after its at full boost? I guess what im asking is, does the boost sensor get its signal before or after the throttle plates?
Originally Posted by RETed
No, not necessarily.
-Ted
-Ted
...which is what the boost sensor tells the ECU to do.
-Ted
Trending Topics
Originally Posted by MrDirt
Arent these symptoms actually indicative of surging, not lag?
The only surge I am aware of is trying to run too much flow through the turbo at too low a boost pressure?
-Ted
I was under the impression that surging was sort of the opposite... too much pressure for the engine's current flow requirements... this always made sense to me because the "surge limit" is in the upper left portion of compressor maps, where the boost is high and the amount of air is low...
CaptainKRM
14
Aug 26, 2015 09:52 PM
