compresion test
Old Jan 22, 2002 | 09:58 PM
zigger1's Avatar
compresion test
I was wondering how do go about testing the compresion on an 2nd gerneration non turbo rx-7?
Old Jan 22, 2002 | 10:02 PM
niner's Avatar
buy the tester.
take spark plug out and put tester in
take out the EGI fuse to cut fuel
have someone turn motor over while you watch the guage
you want to see 3 even bumps for both the 1st and 2nd rotors
they should all be over 100psi if motor has good compression (7.8kpa??? or so)
Old Jan 22, 2002 | 10:13 PM
TonyTurboII's Avatar
Glock Lover
You forgot to throw in "hold the throttle all the way open when cranking."
Jmolina0163
19
Sep 25, 2015 06:06 PM
Mps_hell
Sep 19, 2015 10:02 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
