8" wide rim
Old Oct 20, 2005 | 09:55 PM
perfect_circle's Avatar
8" wide rim
would an 8"wide rim fit a first gen? its got the 4x110. back spacing is unknown as of now. prolly run like a 225, or 235 tire.
Old Oct 20, 2005 | 10:04 PM
Paradox's Avatar
backyard tuner
everything but the 225/235 part will fit
Old Oct 20, 2005 | 10:14 PM
smnc's Avatar
EliteHardcoreCannuckSquad
8" in the front is VERY tight...
Old Oct 20, 2005 | 10:19 PM
$100T2's Avatar
On the prowl for an FB
Just go widebody.
Old Oct 20, 2005 | 11:08 PM
camocarl's Avatar
Run the 8's in the back....but if your on stock, bouncy springs...you will have problems. Carl
Old Oct 20, 2005 | 11:57 PM
steve84GS TII's Avatar
FB+FC=F-ME
If you roll the lips,youll fit out back, depending on offset.
I ran 7" 12MM offset wheels with lots of room to go inward,and right up against the rolled lip outward (with an SE rearend which is wider due to the brakes)
You have to be careful about going too close on the inside of the rear fenderwells too.You wont hit anything going down the road,but if you go diagonal up a curb or driveway,the solid rear axle with tilt inward on one side and youll rub up against the inner fender wall.
Old Oct 21, 2005 | 12:05 PM
well im upgrading my suspension, tokico illuminas, and rb springs
Old Oct 21, 2005 | 01:02 PM
Slammed_GSL's Avatar
Trust me RB rears are not stiff enough, I'm upgrading from RB springs to Coilovers and Eibachs. The Rear Eibachs have dead coils to adjust your ride height. The RB's are a great inprovement over stock, but for drift or Autocross they are just too soft.
Old Oct 21, 2005 | 09:13 PM
Infini IV's Avatar
Microtech Tuning!
Yes, the RB springs are way too soft. I have them in the front for now (until I have my coilover setup built).
I have the Eibach/GC "dead coil" springs (175lb) with Tokico Hp/blues in the rear. The springs are a little stiff for these shocks as my car is a bit bouncy. I'll most likely need at least Tokico Illuminas to balance between the shocks and springs. The 175lb springs should be stiff enough and comfy enough for everyday use though.
Old Oct 21, 2005 | 10:02 PM
nick1's Avatar
is 175 lb the norm for the eibach/ground control rears?
i too have this setup and was wondering what the spring rates are.
i have the coilover perch/eibach spring in the front, and the eibach spring in the back
with the 5 dead wound coils
nick
Old Oct 21, 2005 | 10:03 PM
nick1's Avatar
how are you guys supporting your spring perch/coilover perch on the front of your car? are yo just resting it on the original spring perch? or welding the unit to the strut? or???
Old Oct 21, 2005 | 10:46 PM
Infini IV's Avatar
Microtech Tuning!
I think 175lbs would be a good alternative for someone who might drive their car daily and wants a stiff enough rear. 200lbs rear springs might be a little too tough on the kidneys...
Old Oct 21, 2005 | 10:59 PM
i thought that there was only a coilover set up for the front, and not the rear? am i backwards? can someone post pics iof their coil-over setup
Old Oct 21, 2005 | 11:21 PM
FB+FC=F-ME
I switched to 175lb RB deadwound coils out back.I also run 175lb Eibachs up front and Tokiko Blues all around.
Its a very livable street ride,not harsh at all.True,it may not be perfect for a track car,but my wide sticky tires and increased track width make up for any suspension shortcomings.
I was actually quite happy with the Eibach rear springs that came in the kit with the 175lb fronts and the shocks.They were softer,in the 135ish range I think.The main reason I switched to 175lb rears was to combat rearend squat under power which became a real problem after I started upping the power on my TII swap.The 175 rears keep the car more level under accel,and they prevent the rearend from sucking up and causing my big driveline to hit the tunnel.Plus the deadwounds are great for adjusting ride height,especially when you run adjustable coilovers in the front and you want a different stance.
Old Oct 22, 2005 | 12:51 AM
smnc's Avatar
ISC Racing sells a rear coil-over kit...
Old Oct 22, 2005 | 07:06 AM
Rx7carl's Avatar
Airflow is my life
13x8 will fit in back with rolled lips as was stated, up front no chance. Youll have to slice off the entire factory flare on the fender. I ran 13x8's, 4" BS IIRC when I ran in CSP. 225 or 235's will fit on the rim fine. The ISC isint a "coilover". Its an adjustable spacer used for setting ride height and corner weighting. Up front you can use collars that drop on the strut housing and nest on the factory perch. Of course you need one made for our cars as the perch isint flat or symmetrical. On my IT car I bought the setup from Mazdacomp which requires you to cut off the old perch and weld a flat plate steel perch. on.
So is the Eibach pro kit springs stiffer than the RB ones? I want a stiff street ride without the race car teeth rattling ride. And to save $ I was thinking of using blues.
Old Oct 22, 2005 | 09:36 AM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
I've got 15x8's all around... the lips have been rolled in the front, the rears haven't been touched. They rub a little bit in the front on hard turning, like parallel parking, but at speed, it's not that big of a deal. Also... lemme tell you how much fun it is to parallel park a car with 15x8's, 205/50-15 Falken Azenis, and manual steering. But, c'est la vie... there's better things to worry about.
there's pictures on my cardomain site...
www.cardomain.com/id/chefasaurus
A lot of my friends have dubbed it the "roller skate" because of how it sits with those wheels, but I think it's got a mean, low stance on it. BTW, I run RB springs and tokico blues all around.
Old Oct 22, 2005 | 11:26 PM
nick1's Avatar
nick
anyone have an answer for this?
Old Oct 23, 2005 | 01:06 AM
smnc's Avatar
You're right, I was overstating the fact...
They are only spring perches...
Old Oct 24, 2005 | 05:39 PM
i found a set of enkei rims for sale locally, they are eitehr 15x8 or 15x7 one has 235 tires, and one has 215 tires did enkei make a 15x8 rim?
by the way, it says the backspacing is 7 on th rim, but if thats measured in inches, then how could it be a 7 inch wide rim? or even an 8, because the lip was bigger than one inch...
Old Oct 25, 2005 | 12:06 PM
ttt
Old Oct 25, 2005 | 12:46 PM
smnc's Avatar
Are you sure it was a backspace measurement and not Offset?
Old Oct 25, 2005 | 01:00 PM
kleinke's Avatar
225 will fit in the rear. 225 will not fit in the front without modifications.
DriveFast7's Avatar
Blood, Sweat and Rotors
my car below is 13x8 with 4" backspace. fatty slicks on back, long story, 225/50/13 on front
Old Oct 25, 2005 | 01:28 PM
nick1's Avatar
the 7 on the back of the rim is likely the offset. the 15x7" enkei mesh wheels commonly have a +7 offset and a 2 1/2" lip.
i am looking for a deeper offset for my rears, as i already have a pair of the above mentioned wheels on the front. preferably a 0 offset, or even a low -number if anyone knows of any. enkei, riken, epsilons, etc
oh, btw on fitment.....the 15x7 with +7 offset fit on the front, quite a abit of extra room on the inside, but they are not going to fit inside the fenders...if it gets too low it will rub, and rolling is not going to help....this is on a 85 gsl.....and with 195/50/15 tires
