J-105 Igniters
Old Oct 19, 2005 | 12:07 PM
Vin's Avatar
Vin
J-105 Igniters
I tested my J-105(1980's) igniters.
When I closed the switch during the test the light came on.
But when I opened the switch the light stayed on for about one second.
I varied the rate of switching but it had no effect, the light stayed on for about one second after the last switch closing.
Vin
Old Oct 19, 2005 | 01:46 PM
Vin's Avatar
Vin
Bump
Bump
Old Oct 19, 2005 | 08:28 PM
Vin's Avatar
Vin
Bump
Bump
Old Oct 19, 2005 | 09:08 PM
1stgen4life's Avatar
Leaking oil like crazy!
There is no question. What do you want to know?
Old Oct 20, 2005 | 01:37 AM
Jeff20B's Avatar
Lapping = Fapping
It might be normal behavior. I've seen it happen on J-109s when they encountered too many pulses during CAS testing. When you overload its VR input, the signal conditioner circuit gives up (resets) and leave the C terminal grounded for about one second, which is similar to what you've described.
Old Oct 20, 2005 | 06:55 AM
Vin's Avatar
Vin
Thanks
Thanks.
By the way what do you mean by overload?
Vin
Old Oct 20, 2005 | 10:14 AM
Alak's Avatar
Wouldnt a condensor help in this situation jeff? I had someone explain it to me a long time ago what the condensor does. If I remember correctly, its supposed to absorb any remaining charge, at a very rapid rate, in the circuit when its opened.
Old Oct 20, 2005 | 10:24 AM
Vin's Avatar
Vin
First thing i did
The first thing i did was swap out the old condenser for a new one.
They're hard to test and they’re cheap.
Thanks!
Vin
Old Oct 20, 2005 | 11:54 AM
Jeff20B's Avatar
Lapping = Fapping
I was testing a 2nd gen CAS (crank angle sensor) which has 12 teeth per engine revolution compared to two of a 1st gen distributor. It's actually 24 teeth per engine cycle (two revolutions) for the CAS and four teeth for the dizzy. When the circuit gets more pulses than it was designed for, it stops conditioning the incoming pulses from the CAS or dizzy pickup (VR sensor) and the test light will just sit there and stay on for about one second after the pulses stop.
Alak, I don't know. I always leave the condensor in the circuit for RFI protection.
Old Oct 23, 2005 | 12:23 PM
Vin's Avatar
Vin
Must be...
The light staying on during the test must be ok because my ignition system is fine now and I'm using the same igniters.
Thanks,
Vin
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
