Ignition Woes
Old Oct 19, 2005 | 10:23 AM
Vin's Avatar
Vin
Ignition Woes
*1980 RX7 SA with stock ignition.
*No spark from the leading coil.
*No spark from the trailing coil.
*Both coils get 12.7v.
*High tension wires are good.
*Igniters are working.
*The tach goes to 6K when the key is turned to the run position and drops to 2.5K when the key is turned to the starter position.
*The car uses J-105's.
Since the tach does jump does that mean that my dizzy is working?
Any suggestion?
Thanks,
Vin
Old Oct 19, 2005 | 10:35 AM
smnc's Avatar
EliteHardcoreCannuckSquad
I'd say it's a Dizzy problem, but I don't know jack about points-style systems...
Old Oct 19, 2005 | 10:39 AM
Vin's Avatar
Vin
No points
There are no points.
Thanks,
Vin
Old Oct 19, 2005 | 10:59 AM
smnc's Avatar
My bad...
I still don't know enough about 80's ignitions... Sorry.
I don't know what the difference between the J-105 you use and the J-109's the newer models use...
On GSL-SE's the Tach is triggered by the trailing coil, so if the coil isn't firing, the tach should read 0...
Old Oct 19, 2005 | 03:09 PM
Jeff20B's Avatar
Lapping = Fapping
The '80's tach is triggered by the leading coil because the trailing was semi-firing in order to feed a healthy rich flow of unburned hydrocarbons into the thermal reactor. This was to keep the fire lit inside the thermal reactor.
That's all I know about the '80 style ignition.
Oh wait, there is one more thing. The reluctor of an '80 dizzy has a backwards curve which leads me to beleive the J-105 ignitor triggers on a positive-going pulse rather than a negative pulse, as is the case with J-109 and GM HEI. The solution, I suppose, would be to reverse the two trigger wires if using an SA ignitor on an FB or vice-versa.
Old Oct 19, 2005 | 03:27 PM
smnc's Avatar
Lol... well, more than I know Jeff...
Old Oct 19, 2005 | 05:31 PM
Vin's Avatar
Vin
Thanks
Thanks,
Vin
Old Oct 19, 2005 | 08:27 PM
Vin's Avatar
Vin
Bump
Bump
Old Oct 22, 2005 | 04:37 PM
Vin's Avatar
Vin
Thanks all!
I just got the ignition system back on line. I ripped everything out and rewired the system without the interrupt circuit. Spark is huge. Now on to carburetion.
DLIDFIF should be easy now that I've gone through this.
It was not easy to figure out that the interrupt circuit was wacky. I must have done something to make it go down
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
