West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need to pass smog, what cat?
Old Oct 12, 2005 | 01:04 AM
Cybaster's Avatar
I think I'm addicted
Red face Need to pass smog, what cat?
Hello,
I need to pass smog soon and i am in need of a GOOD cat
what should I use, what are you guys using in your FCs?
if possible hopefully under 150 dollars or so, but if it can't i don't mind either
also is it necessary for a HI-Flow cat? or a normal one would work?
and should i just mount the stock airpump, let the belt drive it and have it pump air into the cat without the ACV? (cuz the ACV is blocked off and i am too lazy to install it... and my electric pump blew a 30amp fuse, so don't know what's up with that....)
what do u recommend doing for passing?
car: 1989 TII stock turbo stock IC
Jonathan
lnlreaper
Sep 27, 2015 09:59 AM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
