Microtech Microtech isnt adjusting the timing
Old Oct 3, 2005 | 08:43 AM
roadkill669's Avatar
Newbie
It just doesnt adjust it. The reading is always at 00*. WTF!! I know That there is an ignition map there, it just doesnt read it. The car idles great and you can drive it with no load at low rpms. But as soon as you go to 10" vac and a little more throttle, it breaks up.
The timing check is off and there are no errors.
Thanks,
J
Old Oct 3, 2005 | 06:11 PM
10sec rx7's Avatar
check your wiring and make 100% sure it is not in timing check modes
Old Oct 4, 2005 | 08:45 AM
Newbie
I know all the wiring is correct, this would be the 3rd time I have installed a Microtech. Plus it runs great, you just cant go past 50% throttle.
I am 100% that it is not on timing check. I thought about that also, but timing check is off.
Old Oct 4, 2005 | 04:47 PM
Newbie
Well, I am now getting a RPM error, so I will check to see if I hooked the ground cable to the CAS sheilding and make sure that it isnt resting on an ignition wire.
Old Apr 3, 2008 | 02:17 PM
Duck0101's Avatar
timing
hey did you ever figure that timing issue out. i have the same problem, my car starts up fine and runs great but for some reason it just doesn't show the timing ret/adv. i've gone over the wireing and the timing is not locked, i'm stuck. any ideas?
Old Apr 3, 2008 | 04:03 PM
rx72c's Avatar
Top Answer: 1
I tried to help you via pm but you didnt reply to any of my questions?
Is your tps switching over from 00 to 01 as soon as you touch the throttle?
Old Apr 6, 2008 | 11:53 AM
Duck0101's Avatar
sorry little slow with the pm and ya it switch from 00 to 01 when i hit the throttle.
Old Apr 6, 2008 | 05:12 PM
rx72c's Avatar
Top Answer: 1
Problem has been sorted.
Turned out his OPT_TIMMAX was set too low.
smikels
Rtek Forum
May 12, 2016 12:34 AM
incubuseva
14
Sep 3, 2015 12:37 PM
