Power FC Please Please !!! Can Someone Help
Old Oct 2, 2005 | 12:56 PM
7 BOUND's Avatar
127,338 OEM, 11.5psi
hey guys can someone please help me, i have been waiting over 21/2 months for a responce to get on the yahoo group and still nothing. I need a updated BASE MOD MAP, i tried the bloomberg one and that does not work, and on the PFC preview it said that it shouldnt be any - splits any were even in the vacum area so i dont want to put that on and pop my engine, when i did all i got was pop pop pop pop so please can anyone just email it to me, exel, aol, yahoo format is fine.
aol = rx7fd405hp@aol.com
yahoo - blue66430@yahoo.com
thanks alot guys
Old Oct 2, 2005 | 01:33 PM
rynberg's Avatar
The Base Mod map at http://opus.bloomcounty.org/~patrick/pfc/ is correct, it is the default map that ships with a PFC.
I still think your problems are either non-PFC related or are due to the fact that you are running that AP-modified PFC.
Old Oct 2, 2005 | 05:48 PM
7 BOUND's Avatar
THANKS RYNBERG well i was told that the only thing changed on the AP PFC was the fuel to ingnition cut, instead of fuel cut, it cuts out ignition. On the PFC preview it said not to have any neg - in the ign split and there are all kinds of neg - in there so am i wrong? Ill try it again, but the funny thing is, when i reset the PFC, its fine but when i add the BASE MOD MAP all i get is the pop po poop
Old Oct 2, 2005 | 09:41 PM
Tim Benton's Avatar
FD title holder since 94
Make sure the base mod map is set to use normal under PIM offset, not option 1, 2, 3, etc.
Tim
Old Oct 2, 2005 | 10:51 PM
Matt Hey's Avatar
Old School
Negative split in vacuum shouldn't cause any problems. Some RX-7 guys deliberately run negative split in vacuum and rumor is the RX-8 runs negative split at idle. Supposedly it allows a leaner AFR. The couple of instances in the base mod map can easily be zeroed out if it still bothers you.
Old Oct 3, 2005 | 05:35 AM
7 BOUND's Avatar
Oh ok thanks guys i went back over the vaules that i dialed in and they were so so off. lol well my wife types 80 words a min so i let her type in the numbers while i called them out, lol well that didnt work lol she was very fast, i think she missed alot of numbers lol but i got it next to mirror like on the bloomberg site. so i will see how it goes
Old Oct 3, 2005 | 05:37 AM
7 BOUND's Avatar
hey tim can you explain a lil more on what you posted, what tab would i find that in what your talking about thanks.
Old Oct 3, 2005 | 06:06 AM
7 BOUND's Avatar
hey tim i found what you were talking about, it was set to normal, but what does that mean, there were those other option, why not pic one of those?
