Needs brake upgrade
Old Sep 19, 2005 | 07:45 PM
dazza Rx7's Avatar
Needs brake upgrade
hey i have a rx7 series one with a series 5 motor and i was just wondering about how i could go about putting disc on the rear or if it is possible or is there a easyer way of upgradeing my brakes
Old Sep 20, 2005 | 09:39 PM
Smoken''s Avatar
Well, if you would take the time to go out and look at your car you would realise that you already have disc brakes on the rear. Depending on the model of your car, you either have two piston or four piston calipers on the front. If you have two piston calipers then find a set of four piston calipers in the forsale section, or go get you some at the parts store. If you already have four piston brakes and your not happy, then you must have something wrong with your brakes. Get you some SS brake lines, flush your fluid and bleed the system, get your some descent pads and maybe some drilled rotors and you should be set. The brakes are pretty good on these cars. There would be no need to upgrade the calipers unless you are doing some serious track time.
Old Sep 20, 2005 | 10:32 PM
dazza Rx7's Avatar
its a 1980 model with drum on the back and im pretty sure it only twin piston calipers
Devon300zx
15
Sep 16, 2015 06:57 AM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
