Power FC Why will the PFC not work in my car???
Old Sep 15, 2005 | 07:41 PM
Sacker90's Avatar
Aint no broke nigga
My car doesn't start up with a pfc. I tried the ecu in a different car and it fires right up. I have the m2 in it now and it start up with it. Any hints will help...thanks alot
Old Sep 15, 2005 | 08:49 PM
McBride61's Avatar
I'll be the 1st to ask you about your mods so some a-hole doesn't tell you "search n00b"
"Whatcha got under the hood of that thing?" auto/stick?
Old Sep 15, 2005 | 08:54 PM
z4csl428's Avatar
From: Seymour, TN (couple miles west of the atlantic ocean)
??? WTF?....
Old Sep 15, 2005 | 09:14 PM
Sacker90's Avatar
Aint no broke nigga
single turbo with 1300 secondaries....and of course manual, but what does that have to do with anything?
Old Sep 16, 2005 | 01:13 AM
moconnor's Avatar
What does the Commander say? Does it power up? If so, have you looked at the sensor check screen? PFC may not be getting a signal from the starter switch, for example. If you don't have a Commander, you should get one because it wil be pretty hard to diagnose what is happening otherwise.
Old Sep 16, 2005 | 09:08 AM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
Could be bunch of things, your best bet is to have pro. look at it, you don't want to mess something up,.
I don't know if you have a commander and/or did this already, but your sec. injectors settings on PFC must be set-up for your 1300's, anyhow I asume you still have the stock primaries so your car should start right up even if the setting are still for 850 on sec.'s , That's just something you will need to do soon or later.
When I installed my PFC, I had to ground it my way, b/c the brackets from the stock ECU didn't work well in that department, I'm not sure if that is realy neccessary but it's a another thing to look at.
The PFC you got, was it new or used when you bot it?
Old Sep 16, 2005 | 11:43 AM
Sacker90's Avatar
Aint no broke nigga
I got it used and it was used wit hthe same wiring harness, secondary injectors, and turbo kit. The injectors are set up right on the pfc.
Yes it powers up just like it should, but just cranks and nothing else. I have a commander and theres a white clear circle besdie starter. I'm guessing that means its reading it...
Old Sep 16, 2005 | 10:57 PM
rynberg's Avatar
If you are talking about the sensor screen, a clear circle means that it is NOT reading that sensor or the sensor/relay/solenoid is NOT operational!
Old Sep 19, 2005 | 03:31 PM
Sacker90's Avatar
Aint no broke nigga
ok...my friends pfc reads everything the same as mine except for the "cat" of the sensor screen...anyone know what that is?
elpartso_robb
Aug 29, 2015 08:45 AM
torky007
Aug 17, 2015 05:14 PM
