Replacing stock turbo with newer stock... new gaskets? (S4)
Old Sep 8, 2005 | 04:09 PM
vex's Avatar
vex
Are new gaskets required when swapping an old, S4 turbo in need of a rebuild, for a newly rebuilt S4 turbo? If so, which, and where can I source them?
Old Sep 8, 2005 | 04:13 PM
Aaron Cake's Avatar
Engine, Not Motor
No, but I would suggest it. Any Mazda dealer can get them, or you can mail order from Mazdatrix.
Old Sep 8, 2005 | 05:01 PM
vex's Avatar
vex
Which gaskets should be replaced according to your suggestion?
Old Sep 8, 2005 | 05:03 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
If you're in there already:
Engine to manifold
Manifold to turbo
Turbo to DP
Thos three would be on my list first.
Second:
The oil/water line gaskets.
Old Sep 9, 2005 | 08:33 AM
Aaron Cake's Avatar
Engine, Not Motor
Anytime you remove something, it's gasket should be replaced. The exception are the exhaust gaskets, which can generally stand several removal/install cycles. But if they are old and original, then replacement is the best bet.
Old Sep 9, 2005 | 10:45 AM
BlaCkPlaGUE's Avatar
I live in an igloo
I heard the turbo gaskets are expensive, just a heads up.
Old Sep 9, 2005 | 10:47 AM
Aaron Cake's Avatar
Engine, Not Motor
They are quite expensive. Be prepared to spend $150 US to replace all the turbo related gaskets.
Kyo
Apr 13, 2019 09:24 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Joe428
16
Aug 19, 2015 06:24 PM
