problems
Old Sep 7, 2005 | 04:22 PM
Vagrant02_DRFT's Avatar
Touge Friend
problems
recently i've been having to jump my car(s4 gxl) alot. after the jump , it would only last 3-5 start ups. in about january 05 i replaced a bad alternator. is this a sign that i need a new battery or is it something else??
Old Sep 7, 2005 | 08:39 PM
88rx7gxl's Avatar
Take it to Autozone. They check that **** for free.
Old Sep 7, 2005 | 09:03 PM
rodney87's Avatar
If the battery's gone dead that many times it might need to be replaced. If you've got a voltmeter check to see that the battery holds a good charge and see if the alternater is getting enough juice to the battery. Start the car and check the voltage at the battery terminals, it should read above 14 volts and if it doesn't then check strait from the alternater. If the alternater is good but the charge at the battery isn't then you've probly got some wires that need to be replaced.
Old Sep 7, 2005 | 09:05 PM
idsigloo's Avatar
Needs more Displacement.
werd, killing the battery over and over again is bad. you might of ruined your battery for not replacing the alternator soon enough.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
