1200 or 1600 injectors with s-afc
im going to be installing a fmic and a 60-1 hifi, is there anybody out there running 1200 or 1600 secondary injectors with just a apexi safc. are those injectors overkill or is that good. what size primary injectors should i use.
they will be way to big, you can only detune 50% with the S-acf, so the max size you would want to use is around 1000, you would be better off with 4x720, which is ok with the SAFC, just get it tuned with a wide band 02
