Sponsored by: CARiD
Magnecor 8.5 vs. 10mm
Old Jan 16, 2002 | 02:21 PM
jmseven's Avatar
Asset is Wealth
Okay....everyone...
What the is the difference performance wise. Is there a REAL benefit going to the 10mm?
Old Jan 16, 2002 | 02:31 PM
jmseven's Avatar
Asset is Wealth
nevermind...I had just found it
11. What gain, if any, will I get using 10mm size wires — compared to 8.5mm size wires ?
Our R-100 (10mm) cable has a thicker insulating jacket, designed for extreme heat situations or where extra insulation is needed for extreme-output ignition systems and where it's not easy to space the wires from one another and/or the engine. Our KV85 (8.5mm) and R-100 (10mm) cables both use the same conductors and provide the same spark energy output, and, as most street and modified production engines don't really need a cable size larger than 8.5mm, using our 10mm size cable is usually overkill (or for appearance). Please understand our 10mm cables, due to their large diameter and bulk, will take more room, and a little longer to fit and loom correctly.
Old Jan 23, 2002 | 12:59 PM
NCsublime's Avatar
I have the 10mm and have no problems whatsoever. I got them free with a tranny I bought from someone a while back. He sent me a brand new set, and then 2 extras that were used.
GKW
Sep 28, 2015 04:34 PM
meximan
Sep 25, 2015 01:39 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
