Several Questions
Old Aug 17, 2005 | 10:05 PM
YayeR's Avatar
Several Questions
Hi I have several questions about my project.
1. For those with a Koyo radiator that's been relocated for an FMIC, do the stock radiator hoses fit fine? If I were to get a Samco 'hose kit' would it fit ok?
2. For those with the FEED front fenders, do any of you run 10" wide wheels in the front? What specs do you use that work?
3. For those with a/c are we stuck with weak a/c or is there anything I can do to make it work better?
That's it for now. Thanks in advance
Old Aug 17, 2005 | 10:28 PM
cewrx7r1's Avatar
Eye In The Sky
Convert the stock R12 fittings to the newer R134. Napa is a good place to get them as they have direct replacement parts to fit the RX-7 instead of getting a crappy fits all kit that sucks.
Then vacuum the unit and fill up with AUTOCOOL
http://www.autocool-refrigerants.com/
which cools better than than R12 and R134.
My car cools better after the conversion in 2003 then it did brand new.
Old Aug 17, 2005 | 10:41 PM
quid's Avatar
Junk the air conditioning. Don't need it.
Old Aug 17, 2005 | 11:21 PM
quicksilver_rx7's Avatar
If your A/C is charged properly and there are no leaks, you should not have a weak A/C. Mine is still using R12 (arguably the coldest) and it will freeze your nuts off.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
