West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Rare 16b prototype unveiled
Old Aug 14, 2005 | 10:47 PM
Rx-7Doctor's Avatar
Found digging thru some of my old Rx history books.
Started in 74, supposed to be released in 77.
Model R160b
Specs. Engine. 16b 1598cc/110ci
Compression. 10.2:1
Output. 198bhp(net)@ 6500rpm. Single turbo JDM only. No Usa version to be offered.
Torque 192lb-ft @3300 rpm
Drivetrain. 5spd Manual
Steering. Standard Recirculating ball. Turns. lock to lock 2.9 Turning circle. 26.5ft.
Wheelbase; 87.2 inches.
The most unique design was of course the engine.
it had what was called quadrotronic rotors. 4 sided rotors in a rectangular design. With the
intake sides being larger for greater air intake and hp.
It had a center eccentric shaft along witht he regular one. similar to todays balance shaft motors for smoothness.
It was driven off a auxillary gear attached to the oil pump system.
5 port design with 5th port for higher velocity of air flow at upper rpms trying to avoid the turbo lag.
Yhis was controlled by what seems a funny terminology. Wankalator valve.
Fuel was delivered by Bosch Fuel injection system with 8 injectors designed to pulse with the 4 sides of the rotors. Instead of being jet-tronic it was called rotronic injection
Dist and ignition circuit were as the following.
2 distributors and 4 coils. Dist being of course the dual point systems. With 1 coil per pulse of the rotor timing.
0-60 times were projected at 6.5 seconds with 1/4 times of 13.5/101.2 mph
Top speed estimated at 155mph being limited to body design at final gear ratio.
Old Aug 15, 2005 | 04:44 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Interesting stuff. Too bad nothing ever came of it.
Old Aug 15, 2005 | 04:52 PM
Siraniko's Avatar
RX for fun
The article was written before my time. Im sure this guys, doctor, is in senior housing and got nothing better to do. I bet he takes viagra 3 times a day.
Old Aug 15, 2005 | 05:23 PM
Kory_yahi's Avatar
Look ma'! I am spoolin'!
agreed.
Old Aug 15, 2005 | 06:03 PM
Rx-7Doctor's Avatar
LISTen UP SoNNY, they got me on an Viagra DRip along with a seperate sedative DRip so i
can get all my proper Up's and Downs exercise.
Old Feb 24, 2007 | 08:15 PM
-xlr8planet-'s Avatar
I has an emblem
rectangular rotors???? I need a pic....
Old Feb 24, 2007 | 08:16 PM
Rx7carl's Avatar
Airflow is my life
Wow thats crazy. Where did yu get this info from?
Old Feb 24, 2007 | 08:33 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Anyone wanna buy a slightly used WANKALATOR VALVE?
Old Feb 24, 2007 | 08:58 PM
fluffysheap's Avatar
Soft & Wooly
You had me going until the 4 sided rotors... you need an ODD number of rotor faces...
Old Feb 24, 2007 | 11:09 PM
DAVID GRIMES's Avatar
How About A Cup Of STFU
And I bet you NEVER roll out of bed in the middle of the night with the blue veined kickstand on duty !
Old Feb 25, 2007 | 11:12 AM
defakto's Avatar
I don't think you do. I'd love to hear why though.
Old Feb 25, 2007 | 10:38 PM
Midwest 7's's Avatar
sellout
another victim of the 70's fuel crunch.
Old Feb 26, 2007 | 12:32 AM
Soft & Wooly
Hmm... well if you think about the inside of an oil pump it has four faces. But I don't think the combustion cycles would line up (i.e. one rotor face goes by and it is doing compression and the next one goes by and wants to do exhaust). I'd like to see working links to pictures of exactly what Mazda was up to, assuming this isn't actually a prank
Old Feb 26, 2007 | 09:41 AM
DCrosby's Avatar
No it's not Turbo'd
Wankel had many star type engines he was developing, the reason 3 faces became standard it was less costly and mechanically complicated.... but that doesn't mean they couldn't be built...
BTW, I thought only Dirt Was Older than you Wackypappy... !
Old Feb 27, 2007 | 02:51 AM
FC_Fan21's Avatar
Tofu Shop Racer
Try to get some more info or pics or somthing im quite interested. Ill post up anything that i find.
Old Feb 27, 2007 | 11:50 AM
Rx-7Doctor's Avatar
https://www.rx7club.com/1st-generation-specific-1979-1985-18/mazdas-original-forgotten-16b-motor-626989/
Old Feb 27, 2007 | 04:23 PM
rotornoob's Avatar
emissions r teh sux
i want pics dammit. this is kinda twisting my brain now.
Old Feb 27, 2007 | 05:25 PM
The Wankler's Avatar
FKITALL
LOLOLOLOLOLOLOL.... nice doc!
Old Mar 2, 2007 | 10:57 AM
glewsRx's Avatar
Bubble Gum's Good
There's no way, the ellipsoid chamber would have to be closer to circular. This sould then lower the volume void at time of intake while increasing the volume of the void at time of ignition. The shape of it wouldn't allow for adequate compression. Off quick math, i'd say you'd get like 6:1
Old Mar 3, 2007 | 11:44 AM
Dinnercoat's Avatar
Caramelldansen
I've seen this design principle before, somebody was touting it as new but I cannot recall the name/url of it.
Old Mar 3, 2007 | 12:11 PM
MaczPayne's Avatar
Mac Attack
^If you're thinking about the quasiturbine engine, then you are mistaken. They are two completely different designs.
Old Feb 27, 2008 | 09:15 PM
teddyrx2's Avatar
One Luv "Till The End"
read that at some point the rotary motor was going to be put into a domestic car...
Old Feb 27, 2008 | 09:20 PM
kungfuroy's Avatar
Chicken Adobo
dates........
Old Feb 27, 2008 | 09:28 PM
teddyrx2's Avatar
drugblock has information on that...i will ask him to post the info in here...
Old Feb 27, 2008 | 09:31 PM
kungfuroy's Avatar
Chicken Adobo
no i mean, look at the date of the last post before yours.....
resserrection
