Mountain RX-7 Forum Serving Montana, Wyoming, Utah, Colorado, and New Mexico
Anybody a master at the sequential turbo system on the FD?
Old Aug 11, 2005 | 04:18 PM
sonix7's Avatar
Question Anybody a master at the sequential turbo system on the FD?
Looking for anyone that understands and can help me troubleshoot my boost issue. I basically did the hose job and custom intake and since then I am only getting 5 lbs max boost on primary and no transition to the secondary turbo. I did replace solenoids while doing the hose job, I don't have the equipment or the know how to test the solenoids, the ones I replaced were turbo precontrol/ wastegate solenoid, charge control, charge relief solenoids all due to broken nipples. I also replaced the intercooler pipes with the hard ones. I am getting only 5 lbs max and sometimes my vacuum is 21 when cruising and letting off the throttle, otherwise it is 15 on the vac side. I had normal boost before I did the job, I just need to know where the problem could be coming from, I am chasing a problem somewhere, anyone think they know what is up? what sounds like the main cause of this problem, is this a normal sounding boost issue? I am stuck.
Old Aug 27, 2005 | 11:53 AM
sonix7's Avatar
nevermind guys, not that anyone was jumping in, I figured out what was up, I have four failed solenoids and a bad charge control valve, I am fixing it and hope it will be done and ready to go.
Old Aug 31, 2005 | 09:27 AM
sonix7's Avatar
***UPDATE***
I'mmmm Back!!! I fixed my sequential turbo control problems, I replaced 4 failed solenoids and a Charge Control Actuator and a ripped y-pipe coupler. I replaced all check valves with Dale Clark's viton check valves and walla, I have full boost and I am almost ready to return to the road, you guys will be seeing me soon.
Jason
Th0m4s
Feb 26, 2019 02:04 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
