wide fenders?
Old Aug 9, 2005 | 09:06 PM
FC3S Timmy's Avatar
ReTripleOG
wide fenders?
ok so i see msports 20mm and 30mm fenders what does the 20mm mean is that how much it can clear (20 offset rims) or not
Old Aug 9, 2005 | 09:16 PM
tripleseis's Avatar
+20mm wider
Old Aug 9, 2005 | 09:40 PM
FC3S Timmy's Avatar
ReTripleOG
so thatll mean instead of a +40 stock offset i can run +20 offset rims?
Old Aug 9, 2005 | 10:56 PM
saott52's Avatar
The msport kit is a wide body kit that 20 & 30 mm means that the fenders are that much wider than the stock ones.
Old Aug 9, 2005 | 11:23 PM
tripleseis's Avatar
Well consider this, i doubt you will find +20 wheels in the stock width in a 17" or 18" wheel. So its not that simple.
Also it seems your concerned with having the flush look and running hipari tire. KNOW that this is the worst place to ask for anything but what simple math based on the stock offsets can provide. With that being said, i've seen the hella dished fn01rs which i think are 17/18 x 10 +10 (with out checking) on an FC before with what i think are the +30 rear fenders. Its all a matter of how you like it. Just a warning tho, low offsets, hipari tire and fender gap DO NOT MIX so becareful when choosing.
Old Aug 9, 2005 | 11:49 PM
FC3S Timmy's Avatar
ReTripleOG
well i was thinking +30mm fenders in the front and +20 in the rear and 18x9F 18x10R with an offset of about +24 i think it should work fine maybe a + 14 would be pretty good in the front leave a good couple mm for clearance
Old Aug 10, 2005 | 08:45 PM
94RHDFD's Avatar
Formally 20b 3rd gen
Well I have the M Sport +20mm front and the +50mm rear. My wheel offsets are 18x10 +38 and 18x12 +26.
Old Aug 10, 2005 | 09:01 PM
fcturbo2's Avatar
i have 20mm front and 30mm fenders. 17x9 and 17x10 wheels.
Attached Thumbnails wide fenders?-picture-371.jpg   wide fenders?-picture-362.jpg
Old Aug 11, 2005 | 07:24 AM
FC3S Timmy's Avatar
ReTripleOG
wow fcturbo2 i want my car just like ur cept different color and rims nice car whats the offset on those
