Microtech Can Microtech run high or low impedence injectors?
Old Jul 31, 2005 | 10:42 PM
RotaryRevn's Avatar
I've been told that most ecu's built in the USA are made to run only the High Impedence injectors. Can the microtech run the low? Or both?
thanks
Old Aug 1, 2005 | 12:21 AM
1sgen's Avatar
583 rwhp 1st gen
yes you can run high and low impedence injectors but not on the same bank
Old Aug 1, 2005 | 04:15 PM
TwistedRotors's Avatar
Compression Tester Guy
Yes. I am running the stock S4 550cc low imp. injectors....2 on each bank.
-John
Old Aug 1, 2005 | 06:03 PM
10sec rx7's Avatar
you can run 2 low impedence per channel or 4 high impedence per channel.
Old Aug 1, 2005 | 07:59 PM
RotaryRevn's Avatar
Sweet, thanks!
Old Aug 1, 2005 | 08:36 PM
RexRyder's Avatar
i have 2 high for primaries and 2 low for secondaries
Old Aug 15, 2005 | 09:22 PM
TonyTurboII's Avatar
Glock Lover
Ditto.
Old Aug 22, 2005 | 04:37 PM
240sx-guy's Avatar
But on a regular 4 cylinder engine, is it possible to run 4 low imp injectors sequental?
Or is an external resistor needed?
eddierotary
Aug 16, 2015 04:12 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
