Power FC Busted PowerFC
Old Jul 25, 2005 | 06:56 PM
BoostorLose's Avatar
Bridgeport Anyone??
Busted PowerFC
Just a quick question. Has anyone ever started the car and the PowerFC stay on the screen that says 'Apexi' instead of going through it's little warmup stage? That happened to me once before, and my tuner said the PowerFC was shot, so I sent them both back to Apexi. They have since been replaced under warranty and I am getting two brand new ones. Before I install one I am going to tear through the wiring to check for any shorts or open wires. Just curious if that happened to anyone else, or anyone has any idea what it could be. Thanks
Mike
Old Jul 25, 2005 | 07:02 PM
Nzo's Avatar
Nzo
TougeTard
Can happen if the commander isnt plugged into the ecu fully.
Old Jul 26, 2005 | 10:19 AM
paulr33's Avatar
this was a known issue when using the wrong hand controller version for the powerfc.
such as using the older say nissan sr20 hand controller on a rx7 13b powerfc.
the newer powerfc and hand controller kits come as one bundle and you need to use 499-a001 now for the hand controller version. but in your case where it has been working fine for some time and then died i have no idea
Old Jul 26, 2005 | 04:51 PM
Bridgeport Anyone??
By hand controller I assume you mean the commander. I had an older PowerFC and the two worked fine. That one fried, so I got a new one and the new one doesn't work. Brand spanking new. I'm going to check the numbers now. Thanks for the help. Would this cause the PowerFC to not work, or just the commander? My car just cranks, no start, and the commander is stuck on that screen. Thanks
Mike
Old Jul 26, 2005 | 05:05 PM
Bridgeport Anyone??
My commander is FCC-ZZ and some numbers, could this be the problem?
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
