Microtech question on ltx8 install?????
Old Jul 25, 2005 | 03:06 PM
jeyjey's Avatar
Question question on ltx8 install?????
hi
when wiring the fuel pump do I use the original relay or do I use the one that came with the ltx8 ????
If I am reading the manual right it looks like I use the one supplied.
If using the original what colour wires do I use as I cannot seem to find reference to them in the manual ?
thankyou for your help
jamie
TII in case your wondering
Old Jul 25, 2005 | 03:37 PM
Broken09's Avatar
I am becoming...
you need to use the one they supply you with.
-Nic
Old Jul 26, 2005 | 11:53 AM
jeyjey's Avatar
thankyou matey
Another question -
Do I need to keep the stock ECU or can I bin it !!!!
Does anyone know the ratio for pre mixing and can you suggest a good quality oil ?
thankyou
jamie
Old Jul 26, 2005 | 12:09 PM
TwistedRotors's Avatar
Compression Tester Guy
Yes, definately use the relay that MT sent you. And toss that stock ECU right out the window!! That's the whole reason to go with a standalone.
For premix I pour in a 16 oz bottle every time I get gas, which usually comes out to 11-13 gallons of gas. I think the popular ratio is about 100:1.
-John
Old Jul 26, 2005 | 12:53 PM
jeyjey's Avatar
this has nothing to do with the install but does anyone know-
How many horses will the stock transmission take ( G/box,prop,diff,etc) - if you have the appropriate clutch and flywheel ?????
12abridgeport
Aug 17, 2015 06:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
