Spark plugs & wires
Old Jul 25, 2005 | 02:54 PM
Max Boost's Avatar
Newbie
Spark plugs & wires
How often do you replace or need to replace them?
Also what spark plugs and wires do you get?
Old Jul 25, 2005 | 03:48 PM
Chuck's Avatar
Plugs in a rotary take a beating. I replace them at about 15,000 - 20,000 miles. I just use the standard NKG's recommended for normal driving. Depending on what kind of plug wire you use, they probably last 50,000. I use Magnecore 8.5 mm and they have always worked fine for me.
Old Jul 25, 2005 | 08:46 PM
ROTORLUTIONIST's Avatar
I'll be boosting soon!!
i use the regular NGKs, and their plug wires, if u suffer from flooding once in a while, remove the plugs and clean them, i do this twice a month, due to N/As being rich in low rpms(wich i usualy stay in), which can cause hard starts(fouled plugs).
i replace my wires every time i replace my plugs, besides, wires are only $26(NGK).
i change both once a year(15k miles or not).
The1Sun
Mar 18, 2018 11:08 PM
PhillyFC
Aug 21, 2015 06:36 PM
sYnth.
Aug 19, 2015 06:27 PM
