Microtech TPS wiring
Old Jul 25, 2005 | 12:40 PM
TPS wiring
Hello, Just got a full range GM TPS and was wiring it up. The MT wiring diagram calls for a +5v, signal, and ground wires. So I started testing the TPS the middle lead (blue, guessing that is the signal) will have less resistance to the on that im guessing is the ground lead (black) and more resistance to the guessed +5v lead (white) when the TPS is rotated. There is no resistance between the white and black leads. Just wasnt sure how the MT worked with the sensor. If it sends voltage to that it will be a short. Can the sensor be wired up with 2 wires only?
discuss
Old Jul 26, 2005 | 08:16 AM
TwistedRotors's Avatar
Compression Tester Guy
nope, you need all three wires and you've got it right:
white +5
black gnd
blue signal
-John
Old Jul 26, 2005 | 01:22 PM
but wouldnt the 0 ohms of resistance between the +5v and gnd leads be a problem?
Old Jul 27, 2005 | 08:53 AM
Yeah, you know what...that is a problem now that I think about it. The +5v lead to gnd lead resistance should be the max of the potentiometer. 0 ohms across those too is bad.....shorted internally.
-John
Old Jul 27, 2005 | 10:02 AM
Cool
well damn
toplessFC3Sman
Mar 20, 2018 01:54 PM
ZacMan
Sep 19, 2015 09:20 PM
